Norco Slight won’t turn on E8000
Batwing
Brisbane Australia
Can someone help me start my Norco Slight E8000?
I haven’t been on my bike for nearly 3 months & when I went to turn the motor on this morning, it’s not responding. My battery is fully charged & I’ve checked all wire connections at the display unit. My wife’s Merida’s bike does a similar thing when not used for long periods of time, however there is a reset button (located behind a rubber grommet) built into the frame. Does anyone know if Norco has a similar reset function?
Seeing as nobody else has responded to this...
I read on here a few weeks ago that some start buttons have their own battery. That battery can go flat if the bike is not used for a period of time (3 months might do it). The cure is to start the bike with the reset button. On the bike in question (sorry can't recall), it was a small hole on the downtube that was directly above the main battery start button. Just push a thin rod down it (an Allen key?)
That may trigger a few more responses. Or you could try the search function.
Hi, I also have a 2020 Norco Sight VLT For Sale and I don’t know where this reset button is. If anyone has an idea please share it. I had my E 8000 motor stop functioning after a rough patch of trail today. It took me wiggling the wires that connect the battery to the motor to get it to start working again. I’d love to know any troubleshooting tips about the Shimano E 8000 motor.
There's no power button reset that I can find on the bike or after scouring Norco's manuals. My bike 2020 Norco Sight VLT C2 and I've had the same problem 3 times so far. Happens after the bike has been on a ride working just fine. The led for the button is lit up, and the display comes on, then just quits. I've had the charging port replaced under warranty (E020 code intermittently). I'm not sure this is a hardware issue, since this problem always magically heals itself over night without me touching the bike. My firmware is all up to date, so the only 2 components left are the wire harness inside the downtube between the motor and battery and the power button. Looking for any suggestions as my Norco dealer is an hour away and not the best shop in the world at that.
Side rant: I think it was a really poor design decision for Shimano to supply the display, shifter, motor, and battery, but expect the frame manufacturers to integrate their own button on the bikes. They were probably thinking: "oh well it's just a switch, how hard could it be?" but it introduces more complexity for no reason. Cost of bikes go up because they have to manufacture a hole in the frame + supply a button. Not only do we get more proprietary parts, but we get electrical components from a bike manufacturer. Are we surprised there's design/quality issues? What does all this get us? The Ironman heart button on the Norcos looks horrible, and the Decoy's button is hidden under the top tube. So we get more expensive, more proprietary, less reliable, less good looking bikes, all because of an engineering/design decision.
Full stop, the power button should live on the display. If this problem happened, the fix would be as simple as replacing the display.
Does your bike have Shimano battery?
If you put a Allen key in a chain ring bolt and pedal the bike backwards pretty quickly as if you were lubing the chain the bike will turn on. Use to happen on my sight all the time. Does it on my Levo now too.
Mate this is IMPRESSIVE you‘ve discovered, the “Allen key crank reversal kick start”….. So l am guessing on here, you would still press the on off button…. Then apply the Allan Key and proceed to peddle backward….
My Sight can and often expresses from applying with a lazy “ON” button response, slow to engage, hasn’t completely given up but showing up as possible signs ay…. Mate totally appreciate with your reply to this thread!
Thanks….
Nah you don't even need to hit the power button. Just cycling back fairly quickly will turn the system on.
My Sight did the same thing after a bumpy 38 km epic ride. A Norco dealer couldn’t resolve the issue so they called Norco for help. After 2 days of no responce, i picked up the bike as we were leaving the area the next morning. When I got the bike back I decided to drop the motor and check the connections. It wa not difficult and sure enough one of the black bullet connectors was loose. Cleaned everything up, made sure the connectors solidly clicked into place, reassembled everything and no problems since.
Dealer replaced my wire harness ($175 labor cost) and 2 rides/30 miles later it seems to be working fine. No error codes or anything. Guessing there was just a short in the wire that developed after about a year of riding the bike hard. Seems that Norco has ditched the wire harness on their new VLT bikes, since the charging port is integrated into the battery.
It's interesting to me how we're on the 3rd generation design of the Sight VLT, but still only the first generation design of the YT Decoy, which anecdotally, seems to be a much more reliable bike. I also broke my Sight VLT's alloy chainstays, and have never heard of a broken YT, carbon or alloy. Love how the Sight rides but with these 2 major issues, it's hard to not look at this bike as being a lemon.
When I removed the motor I noticed a couple og spots where the wires were pinched. The hardest part of the job was getting the motor back in. There is a channel under the motor where I secured the wires with “Gorilla” tape to hold them in place during the reassembly.
hello Silver Fox,
I have a Norco Sight VLT A1 and have been experiencing what I believe to be the same problem of riding bumpy single track with the motor turning off, & the display going off. Switching the bike on "lites" the display up momentarily, but it turns off straight away. The bike has been to the bike shop numerous times; battery replaced, but still no fix. I don't know if the bike shop dropped the motor. Is dropping the motor and checking the connections a job for the novice? Are there instructions anywhere? I am tired of walking the heavy beast out of the bush.
regards Jpt_1
I unbolted my motor just to see if the connections were clean and my dealer told me that voided my warranty but that they’d do me a solid and only tell Norco if they asked. (Dealer was a total joke and I will be buying a consumer direct bike next).
I had my charge port and my battery wire harness replaced under warranty. The wire harness seemed to fix the issue with a few test rides, but I’m really not certain as I sold the bike shortly after.
Norco was a great company to deal with warranty when I broke the chain stays on the bike, but of all the bikes I’ve owned (Ibis, Santa Cruz, Nukeproof, Specialized, Transition) the Sight VLT was the biggest POS by a wide margin and I doubt I’ll own another Norco. It’s telling that the Sight VLT has gone through 4 generations in the same time the YT Decoy has stayed the exact same.
I broke my chain stays too. Turn the aluminium on both sides. Must be made of cheese
Mine totally broke through on one side and was halfway ripped through on the other much like yours! It's funny because the marketing usually goes: "strong alloy on the chainstays where it matters" when that was the only non-carbon part on the bike and was the one that broke! Could never feel confident in the bike again after that. At least Norco now has a lifetime warranty and they don't want to go replacing chainstays forever on new models so that gives me a bit more confidence in their newer stuff.
  • Like
Reactions: iXi
When they replaced mine they couldn't get the sight vlt chain stay so they gave me a different model which was for a 29er, it lowered the bottom bracket by about 20mm and I was pedal striking everything. I sold the bike not long after.
I loved my sight even though it was a bit small.
    668K
