Oooh. Can I have the crank out of it? Cooperte shouldn’t need that bit. It’s a simple remove from the pcb end.We’ve got one that’s got a shagged pcb due to it being on the floor and the house was flooded. It belongs to mate so not sure what he wants to do with it . I’ll ask
I’ll ask, but knowing the owner he keeps absolutely everything , Inc the box it came in .Oooh. Can I have the crank out of it? Cooperte shouldn’t need that bit. It’s a simple remove from the pcb end.
Blinkin hell, you’ve put some work into that! I do quite fancy the hub and ditch the rear clanger setup.As an aside, did you see this?
My Rohloff/belt conversion
OK lets get one thing out of the way first. This is not about derailleurs being crap/hub gearboxes are better. It’s not about weight, it’s certainly not about cost. This is simply about me indulging myself. Perhaps one caveat regarding 1x drive trains on mtbs, is there a less aesthetically...www.emtbforums.com
I quite fancy the new geared hub, what do you think of it ? Did it fit ok on the moterra ?
Seriously impressed!As an aside, did you see this?
