1st EMTB build frame options
Nashwillis
TN
I am looking to build my first emtb, I have gone thru the forum and see a lot of info on the dengue E10 but not available in the USA. I will use the bafang m500 or m600.
Light carbon has a frame people have used, maybe an issue with a cover?
I am wondering if anyone has experience on some of these frames. If there are more let me know.
Ican e11
Diycarbonbikes
Looks like the trek rail, comes with motor and battery already. Might be more expensive since put together already.
Check out the thread I just created in this section called VMG Typhon discussion. It by far looks like the best frame option.
Do check the geometry of the frame guys, I found when buying the E10 most of the others available had the geometries of about 5 year old frames, we’ve moved on a bit since then.
Its not a game stopper though as with a bit of ingenuity you can say go Mullet and or fit head angle changing bearing kits. Do also consider the slacker the head angle the less suited to single track, maybe you want a more agile bike.
In my opinion, the Typhon has the most modern geometry of all Bafang frames.
I'm biased of course 🤣
I second what VMG Chris stated. The Typhon is by far the most modern Enduro DIY Ebike geometry wise.
I have not received mine yet so I can't comment on anything other than the numbers on paper.
Recommend our LCES004 EMTB carbon frame set:
Hi JimLee,
I have an LCES004 and want to switch to a coil shock. It appears the rear suspension leverage ratio is fairly linear on this bike, is that correct? Would I want to use a progressive coil spring then? Thx!
Hi JimLee,
Hi my friend,
LCES004 can use the coil shock, make sure eye to ey length can not more than 195mm
    Join 43,185
