Swapped E7000 for E8000, but wont turn on
jimbob
518
429
East UK
My bike has been in for a warranty claim on the motor for the last month, and was told the other day the new one won't arrive for at least another month. Someone I know bought them selves a spare E8000 (new) motor off of ebay recently, and offered it to me to tide me over.
I've just tried fitting it, but when I go to turn it on, the display lights up for a second and then turns off. It's as if the motor isn't connected (I've cleaned the connectors). Tried charging the battery for a couple of mins unless it had gone to sleep, and also removing and refitting the battery but no change.
Any ideas?
Spiff
414
239
Earth
Check cables for display, assistance switch and and speed sensor.
You'll have to configure motor angle and wheel diameter in the LBS.
Tone461
105
189
West Midlands
A few possible solutions in here. Whipping the charging lead out worked for me.
KTMJack
74
27
Oakley Ca.
The displays are different You might have to use the e8000 display A friend of mine wanted to put a E8000 display on his E 7000 and it would not work
jimbob
518
429
East UK
Thanks. My understanding is that the E8000 display only works with the 8000 motor, but the SC7000 display works with both the 8000 and 7000 motors.
Spiff
414
239
Earth
Motors DU-E8000 and DU-E7000 can use both displays SC-E8000 and SC-E7000
But Motor DU-EP800 can use only SC-E7000 (With cable adapters) but not SC-E8000 (Also can use SC-EM800 without cable adapters)
jimbob
518
429
East UK
As an update, I tried it with 2 E8000 motors and neither would turn on. I managed to connect to the display (via Bluetooth) by plugging the charger into the bike which then powered the remote switch and screen. I could see the serial number of the motor, so don't think there was a connection issue on that side.
The bike shop has just installed the replacement E7000 unit with no problems, so don't think there is an issue with the cabling / connectors on the battery side.
Which leads me to the conclusion the motor wasn't asking the battery to power on for some reason. I can only think there was something not right in the firmware? I think ive read on other threads on here others have had to update the firmware on a new motor to make it work?
I'm tempted to buy a plug in shimano box to see if I can get it to work that way. Otherwise I may have a useless motor on my hands!
steve160
14
Perth Australia
A sc e-7000 worked for me on the original eu 8000 but not on the one I just got from Germany which is running 4.5.5 software from memory. The bike works, just no display.
Spiff
414
239
Earth
This could be the reason, some motors DU-E8000 from Germany are at an old FW level, but DU-E8000 motor got the support for display SC-E7000 with FW 4.7.1, which was released on 2 Sept 2019.
So if motor DU-E8000 is at a lower FW level, then SC-E7000 won't work.
jimbob
518
429
East UK
Thats very useful, thanks. I never did get it working. The new motor arrived before, and although I've been meaning to have a play, I've prioritised riding over stripping it down! I have now got the shimano PCIE interface and was planning on installing the motor and updating all the firmware at some point to see if that solved it, which hopefully it will.
A job for a rainy weekend I think.
steve160
14
Perth Australia
Yes they are, read above, juat depends on update version its running. Regardless of whether the one that the German is selling is nicer the 7000 is more compact and stealth.
steve160
14
Perth Australia
So if you install the 4.7.1 version the 7000 display will work.
KTMJack
74
27
Oakley Ca.
Yes they are, read above, Twat depends on update version its running. Regardless of whether the one that the German is selling is nicer the 7000 is more compact and stealth.
No... The 7000 black and white display is garb and won't work with the E8000 motor There the same size butt the newer nicer one is for the E8000 motors. Why would you want the old school one
steve160
14
Perth Australia
You need to do some research mate, the latest 7000 was brought specifically for emtb as it is more compact and therefore less likely to be written off in a crash. And once again they do work with the 8000 because ive had one.
KTMJack
74
27
Oakley Ca.
They must be different on your side of the world We don't have any E7000 Shimano's anymore here.
I sold my Shimano's and went Gen3 Specialized more power reliable and quite
jimbob
518
429
East UK
Either way, I did buy a E8000 display and that didn't work either.
I also didn't like the fact it was larger than the 8000, although I never rode with it.
524K
