Fox Float X2 mounting on Rail?
dochabanero
Sweden
Hi!
Never cared much about Rockshox shock on my Rail. Yesterday one of the Trunnion mounts failed as well with half the bolt still stuck in the Shock. Said and done, new Fox X2 Factory 230x60 on order, but what else do I need?
Since the old is Trunnion style mounting I need a mounting kit:
OEM Upper Shock Axle + Nut
OEM Lower Shock Axle + Nut
What else, would assume bushings, spacers, etc, (part numbers for those)?
I’m sure we have many on here that has done similar conversions. I’d appreciate some help.
I’ll answer this myself. (2020 Rail)
Trek OEM upper axle and nut
Trek OEM lower axle and nut
Fox 54mm, mount hardware for a 10 mm axle
Fox 40mm, mount hardware for a 10 mm axle
AND!
Two new lower mount ball bearings. Old ones are dead.
Bike is a size L (carbon frame)
What’s the exact shock name that I need sorry not to savvy in mtb really thinking about going over to fox setup or upgrading my rockshock setup
Fox 50mm, mount hardware for a 10 mm axle
Thanks @dochabanero, could you confirm the Fox part numbers for these?
FOX Mounting Hardware - 9 Piece, SS, 10mm x 49.78/1.965OS Mpn: 803-03-338
FOX Mounting Hardware - 9 Piece, SS, 10mm x 39.88/1.570 - Mpn: 803-03-314
No, so these are the ones I got:
54mm kit = 803-03-311
40mm kit = 803-03-329
The top Mount is 54mm, sorry for typing that out wrong. Got mine from bike-components.de.
I know TF-tuned in the UK also sells these parts if you talk to them.
Any issues with frame clearance? Looks like it can almost hit the seat tube.
No I had no clearance issues. Sure a tight fit, but no issues even bottoming out. I had my X2 in a L carbon frame. Best upgrade ever on that bike!
