will the orbea rise see any updates
There is something called Myo. Check it out.
Considering how popular the Rise is, I'd say they will update it.
There will be, always is. This this only the 2nd year of the Rise, so maybe next year, if not, then by 2024 at the latest. I suspect 10mm more travel front / rear, slacker by 1 degree. The bigger battery as in the H model.
I'm guessing the new cells from the H battery, and maybe 400ish capacity, I think they really want to keep the sub 40lb builds on the spec sheet, maybe the range extender can get a bump to a full 200 as well. I don't think travel will change, maybe geo a bit, but one would think a e-rallon would be on the table for the travel half of you are trying to get out this bike :)
The data sheet says the RE is 252. Mike said “maybe the range extender can get a bump to a full 200”. Confused 🤷‍♂️
Got a new Rise M10 today (for my wife) and it came with Fox X factory shock while my M10 purchased in may last year came with DPX2 factory. Rest of the bike seems identical.
