Trek Rail bearings table
Hamina
FIN
Made myself an excel for Trek Rail aluminium bearings and thought that I could upload it also to here at the same time:
PART #TREK PARTWHERETREK #PCSBEARING MODELSIZE
18Rocker: Seatstay BearingSeat stay - PivotW5292242 pcsEnduro Bearing - 3800 MAX LLU - 8mm wide10 x 19 x 8
23Rocker BearingFrame - PivotW5865432 pcsEnduro Bearing - 3801 MAX LLU - 8mm wide12 x 21 x 8
28Main Pivot BearingChain stay - PivotW3020252 pcsEnduro Bearing - 3803 LLB-W17 x 26 x 10
32Shock Mount BearingRear ShockW2934664 pcsEnduro Bearing - 6800 MAX // BB 6800 LLU MAX10 x 19 x 5
16ABP BearingABP Rear AxleW5834242 pcsEnduro Bearing - MR 20307 MAX20 x 30 x 7
I looked the part interchangeable from here: DIY MTB
Paul Mac had the same information here: Bearings. - EMTB Forums
@Hamina thanks for this...will this suit the 2020 Rail? Or do all Rails use the same bearings...
I think I took the numbers and models from 2020 aluminium pictures. The one that’s posted sticky thread here.
You can crosscheck the OEM numbers
    675K
