Trek Thru shaft bolts
monty1991
Northern Ireland
hi. could someone point me in the right direction for the 4 bolts I need
W583804 is the part number but Google search doesn't really help
ther for a aluminium trek rail 7
My link is a different part number from yours by the way, mine is W547868
Just checked, your part number is wrong, yours is for the pivot bolts.
if the bolts are for the shock a suspension specialist is the best bet to get the right ones...............like TF tuned as I linked a bove.
The bolts he needs are Oem so surely better to buy from a Trek dealer. As far as I can tell the tftuned ones are for converting trunnion to pin and not the other way round.
I think this is the correct bolt my only concern is the trek manual says its 17nm while the bolt says 10nm. any thoughts on this? or am I over thinking it 😆
I’ll have a look at mine when I get home👍
Mine is the same size dimensions as the one at Triton but mine says 17nm on it. Probably best to ask Triton, i've bought from them before and they are very helpful.
    675K
