Levo Gen 2 Rockshox Deluxe Select+ to Super Deluxe Ultimate. Problems?
cuaion
Denmark
Hi,
My stock Deluxe select+ is close to dead :(
I have 2 options for a new. Deluxe Ultimate or a Super Deluxe Ultimate.
But I can't figure out if the Super Deluxe will fit a 2020 Large frame?
Second problem, which tune? Stock is Rx tune? The one I can get right now without waiting is medium/medium tune. But anyone know what stock tune is (rx tune)?
Super Deluxe 210x55 will fit but you might need to replace watter bottle for smaller. Stock tune is LH320 or LH380.
Thanks salko,
Do you know what the diffence between LH320 and LH380 is?
Wunder if a "normal" shock with MM will be good or bad.
Do you know if 210x52,5 (stock stroke) in super deluxe will fit too?
320/380 is Lockout Force, yes 210x52,5 is stock dimension and surely it will fit, maximum is 210x55 ...
Thanks again,
Then im you back to the tune problem, since only available is MM tune
Get the shock, the tune can be altered at your first service. in the meantime, there is always something you can do to reduce whatever dissatisfaction you have with the existing tune.
Think you are right!
Do not think I will make it to first service anyway, since ETA on my 2022 Levo is mid December :D
    Join 43,151
