All Mountain Coaching
So I know it's 150 travel, but what is the shock size. Eye 2 eye etc if I wanted to replace the shock. Thanks in advance.
Thanks. That's a shame. Was gonna get the fox X2 in the sale from CRC but that size isn't an option.REAR SHOCKFOX DPS Performance, 210x52.5, 150mm of travel, 3-Position Adjustment, custom tune
WHEELS
I actually like the stock shock. If I were to upgrade it would be the Ohlins TTX Coil which they do make for our bikes.
How much do these go for?
Would you still go for it if I said the fox x2 is roughly half that price?How much do these go for?
Retail is $650 for the shock and $95 for the spring.
Good question. I've run both the Fox X2 and Ohlins TTX Coil and my preference is the Ohlins TTX Coil. Mainly because I prefer coil suspension. I do think the X2 is the best air shock though. You found one to fit our bikes?
If you are 200lbs + I would go for the Ohlins TTX Coil 100%. I see heavier riders maxing out the X2 psi often.
Cane Creek DB Coil in-line is another option and they do a 210mm eye to eye version. £330.00
The only reason I didn’t buy one of these is because I had the Cane Creek Double Barrel Coil already in stock.
Follow the link below to plush rear suspension at an affordable price ?
DBcoil IL
Your local Specialized Dealer or Ohlins USA direct will sell you the shock and spring. The Cane Creek Coil is a good deal and worth looking at if budget is a concern. Just stay away from the Ohlins and Cane Creek Air Shocks.Can you send me links on exactly what to get for the Öhlins Coil? Im interested in trying this coil out. I seem to have to ride with really high pressure on this RockShox Deluxe.
You will need to check with them via email or phone to make sure they fit the correct size bush kit for your bike model and year. They will ask for your weight and riding style so they can tune the shock for you so it will be a simple ‘fit and ride’ process for youI like that, which option do I get? Ship to USA too? Ill give this a try....straight bolt on yeah? No need for Bushing Kit or anything?
Ended up going Cane Creek.
After consulting with them, here's what I decided on:
DBcoil CS 210 x 52.5
VALT 2.00in x 650 Coil
Hardware - 20mm x 6mm for Top
Reuse Flip Chip for Bottom (according to Specialized)
Waiting for it to arrive and will post up when completed. Sorry for somewhat hijacking, but hopefully the thread was useful to gain more info on what OP was looking for.
DBcoil IL
............. I seem to have to ride with really high pressure on this RockShox Deluxe.
VALT 2.25in x 650 Coil
Did you get a db coil?I'm also evaluating the purchase of a dbcoil IL, but I noticed that in the tftuned.com page of this shock, there is written:
"Note this shock is not compatible with 2019 Specialized Stumpjumper or Levo Models"
It is an error in the description on the site or it really is not compatible with the 2019 levo.
How did it go?
