Touring Hybrid PRO Mns Perf 65Nm 625Wh 21
omn
Norway
Hello all. I have just bought my first elbike.
I am new at this and i think i want to change from Bosch Intuvia to Bosh kiox , smartphone hub or nyon. If i do that do i have to put new cabel from engine to the new display. or just use the cabel that is for the intuvia.
Hi there
I've upgraded from the intuvia to the nyon. I chose to fit the older nyon as it was really easy. The nyon is fully compatible with the intuvia holder, so no wiring required, even works with your current handle bar control. Dead easy and a great up grade, wouldn't be with out it.
Another bonus by choosthe older nyon display is because it uses the same holder (handlebar carrier) you can use either display to suit your daily requirements
Has any cube owner with the basic purion upgraded themselves and retrofitted a kiox? Was the process straightforward? I assume it’s just running in a new cable and plugging into the same port that the purion is connected to?
    675K
