Renthal vs One Up Carbon Bars
Shinn
Decorah, IA USA
They look very similar, as do most carbon bars. the one up bars are intriguing to me with their ovalized sections and claims of less vibration. I don't see they have a 30mm rise and fear 35 is too much.
I'm leaning towards the Renthals, they come in a 30mm rise at 760mm which I think will be perfect.
I've always ran alloy bars, almost always from Race Face and this will be my first foray into carbon bars.
Anyone tried both? Any reason to stay away from carbon these days?
Thanks.
Thanks.
I have both on separate bikes.
The feel is noticeable between the 2 of them. And I would have to say, I enjoy the compliance in the one up more. (The renthal is very stiff)
I have an 800x35x35 rise Renthal carbon fatbar on my Remedy. It is as stiff as a stiff thing. I tried it on my Rocky but it was too much for my daily ride I found, so I put the oem Rocky alloy bar back on which is noticeably more compliant and comfortable.
Do you not have 5mm (or more) of spacer under the stem? If not, then the 35mm rise might be too tall. Do you have 10mm (or more) of spacer above the stem? If yes, maybe get the 20mm rise and swap a 10mm spacer to under the stem.
I had Renthal Fatbars in alloy and they were a big improvement on the bog standard no-name I had before. Then I got a cracking deal on the exact same Renthal bar except it was in CF, the Fatbar Light! The difference was immediately noticeable. Pretty much all the vibration was gone and every rock felt as though the corners had been rounded off just for me! :love:
But after a couple of rides it all became the new normal. :rolleyes:
I have spacers, just trying to keep them to a minimum as the reach on the SL is pretty short...I know the change is minimal but still keeping it in mind.
Hey Guys,
Carbon handlebars is one of the upgrades in want buy in the near future. I'm looking for more comfort and have heard carbon bars filter out alot of the vibrations compared to aluminium bars. Are there brands that are better then others or some that are to be avoided? Do i need a special stem for it or can i use any stem?
What do you weigh?and how do you ride?
If you are heavier or an aggressive rider (and especially both) oneup carbon bars flex disconcertingly.
I can bend them noticeably in my hands without them even being fitted to a bike.
Renthal vs. OneUp is the topic here. In general, my vote goes to OneUp as the most comfortable bar I've used. I'm at 100kg with these bars fitted to my current hardtail, trail, enduro and gravity park builds with a plan to install on my eMTB, when it arrives. No worries from me regarding the strength and they provide an adequately stiff steering experience. They come fairly wide (easy to cut if needed) and are offered in two rise options (20mm & 35mm), but just one clamp diameter. For the stem, anything of good quality designed for a 35mm bar will have you properly setup.
Hey Guys,
I like my 800x35x40 renthal fatbar. I run another carbon bar, Spomann Carbon, it’s meh. I also run an alloy Vibrocore. Fatbar has the least vibration and feels good to me while riding. It’s subjective but I like my Fatbar the best. I have not tried one up carbon bar.
170lbs
about 170lbs or 77kgs, my local trails are mostly rolling single track which is full of roots and some occasional rocks (good fun). I travel often though to very rocky areas, lots of drops and high-ish speed rocky descents. (really good fun)
The one up bars now make me nervous, locally they sound great but there are some sizeable drops I do enjoy immensely.
I'm on a M Levo SL with short legs and longer arms.
Thanks for the comparison between the fatbar and vibricore. Thought if I stuck with alloy I'd look into those a bit more.
40mm rise seems like a lot to me - you must get to go down the hill much more than I.
Cracking deal, the bars were cracking or is cracking a good deal in your neck of the woods? Sounds like they're cracking and they gave you a deal? I'm confused. While we're at it - what is a bloke? I could google it but figure the responses here would be more entertaining.
Lots of long 60% grades DH.
170lbs
You'll be fine with one ups. I've found them really good for reducing vibration. They are 35mm so you'll need a 35mm stem.
If you're really after comfort look into cushcores & reduced tyre pressure - but thats another topic
Cush core is still in the box as its winter
Whats a bloke you ask ..?
This should give you the answer but you will have to wait until the end to find out ..
Well with 95 kg im on the heavier side of the scale. I'm not really an agressive rider.. a bit in the middle i would say. I would be mounting them to a Cube hardtail.
Jeff's trails have no corners.
Cornering fast downhill requires weighting bars way more than climbing requires the "yanking" he hated.
For me, vertically super flexible handlebar is horrible cornering.
If you are a DH rider and finding your bars too stiff on 3ft drops you're weak. Plain and simple.
There's no way I'd run oneup bars and stem on any bike. Infact I was offered a set for free last year and declined.
Honestly I’m surprised to hear people say the Renthals are too stiff. I run the carbon Fatbar 40mm rise on a Turbo Levo and an Enduro. I have an ENVE carbon bar on my XC bike. The ENVE bar is STIFF. I can slightly flex the Renthals in my hands somewhat “easily”. They absolutely absorb a great deal vibration. I don’t think I would want any more flex in my bars than the Renthals. The direction of flex is important. How they layup the carbon can give different flex in different directions. To each their own I guess. I’m 6’4” 225lbs, 1.9M 100KG. There was another carbon bar review video that was pretty good that compared all the top end Carbon bars not that long ago - Renthals, OneUp, ENVE etc. I’ll look for it and post if I find it.
20 years of climbing rock and ice has left me with bad wrists, tendonitis and cubital tunnel syndrome in both elbows. Certainly not weak, am I as strong as I was 20 years ago? Nope.
Just trying to find a more comfortable solution to the RF 35mm alloy bars I'm currently running. I have a 2.6 DHF and cushcore waiting to install so I can get the pressure down a bit closer to my last bike that had 2.8's.
I'm certainly still on the fence about the one up bars. I just want to continue riding for as long as I can, steering is important but so is being able to hold on to the the bars.
I'm more worried about them breaking.
Can't go wrong with some Dire Straits. I'm still a bit of a fan of Mark Knopfler excellent guitarist, not the greatest writer though.
Much better definition than I would have gotten from Google.
Honestly I’m surprised to hear people say the Renthals are too stiff. I run the carbon Fatbar 40mm rise on a Turbo Levo and an Enduro. I have an ENVE carbon bar on my XC bike. The ENVE bar is STIFF. I can slightly flex the Renthals in my hands somewhat “easily”. They absolutely absorb a great deal vibration. I don’t think I would want any more flex in my bars than the Renthals. The direction of flex is important. How they layup the carbon can give different flex in different directions. To each their own I guess. I’m 6’4” 225lbs, 1.9M 100KG. There was a carbon bar review video that was pretty good that compared all the top end Carbon bars not that long ago - Renthals, OneUp, ENVE etc. I’ll look for it and post if I find it.
I run the same Fatbar as you. My other 4 bikes run a variety of other bar setups. I’m 225lbs as well and hands down I prefer the Fatbar. I tend to have less hand fatigue. My vibrocore is probably my worst offender with hand fatigue but it could be that I’ve got it installed on a boxxer fork.
Nice video. Supports why I like my Fatbar. It’s suited for my type of riding. I can see the one up being better for a different rider or different style of riding or different trail.
I've watched that a few times now. Thanks for posting it though, others may not have.
I don’t think I’d worry too much about them breaking honestly. For me it comes down to bar control/control of the front end. I think too much flex up front makes for less power pulling up over rocks and roots and less responsive in technical climbs. It also lessens my bunny hop/manual power. I tried those REV grips for a short time. Though they helped with some vibration, the loss of power in my bunny hop from pulling and twisting the bars was too much. The Renthals are the sweet spot for me. I don’t want wet noodle bars on my bike.
Of note, I have a 25 year old wrist injury, an old hand fracture and a old thumb tendon injury.?
Just FYI. I ripped rev grips clean off the bars first time I tried them. Just messing around bunny hopping and manualling in the street.
    670K
