Chain Guide
gogsie
21
21
Sauchen
I have a 180 and was wondering the same thing. I managed to badly score the frame at the bottom of motor area and would like to fit a bash guard also if thats possible, so far google has failed to produce any solutions for me.
Wilko58
100
88
Chorley
Rickguardz do a carbon bash guard. I don't think there is enough room on the Whyte for a chain guide. The spec on the Whyte website says (I think) that bikes have a chain guide under one heading but under the chain guide heading (ISCG) it is blank.
Giff
428
117
Cheshire UK
Thanks Wilko58 i have contacted Whyte who said they think one should fit but haven’t tried it. I have one in order from Nukeproof so will post if it fits.....or not?
Giff
428
117
Cheshire UK
Update on chainguide....it doesn't fit. It will rotate to line up the bolt holes but there isn't enough clearance for the guide.
MrPeaski
249
207
South Wales
@Giff The E13 guide I mentioned (in your other thread) would probably be the same as it looks very similar in shape.
For your bike I thing the bolt holes need to be longer so you can rotate it further.
EDIT: just noticed your original link is not a Bosch Gen4 fit but ISCG 05....Maybe the E13 will fit?
Gary
Old Tartan Bollocks
10,496
10,691
the internet
What motor are you trying to fit the chainguide to?
Bosch gen 4?
you need an E spec guide.
it'll be a different bolt circle to ISCG05
Wilko58
100
88
Chorley
Have you another link to the Facebook picture or a screenshot, it says this one isn't available.
The OP has just added "Two bolts only, the only tricky thing is placing the washers - need 3 or 4 to centre over the chain. I used grease to stick them together ??"
MrPeaski
249
207
South Wales
@Gary The OP has had a couple of suggestions for his bike which is a Bosch Gen4.
The issue he has is that Wyhte have adjusted the angle of the motor in the frame (for ground clearance?) so the suggested gen 4 pattern chainguides don't have quite enough adjustment.
Wilko58
100
88
Chorley
i don't have Facebook.
Nukeproof don't make Ebike chain guides
The FB post is in this thread above. You've got two posts crossed, the Nukeproof doesn't fit as the OP found out but the one on FB is a foreign cheap ISCG5 one and apparently does fit.
Rahr85
494
1,058
nottingham
following up on this thread i came across this.
may 2021 you say... best get ready for it.
524K
