Speedbox (Or similar)
Rob J
Sheffield
Anybody fitted a Speedbox chip (or similar) to their Gen4 Motor?
I have a 5 month old Stereo Hybrid with the 85Nm power upgrade and was curious to know if anyone had chipped their ride.
Guy at the bike shop warned against it but still curious.
Cheers
Rob
I used a Speedbox 3.0 for approx 900 miles and now a Volspeed V3 for 300, no problem with either.
Why did you change from Speedbox to volspeed
The countdown with the Speedbox wasn't much of an issue initially, the 1-2 minutes as I put my bike away wasn't a big deal, but as I did more commuting to work, whilst waiting at traffic lights or pedestrian crossings, the Speedbox would go into countdown mode, which meant a slight delay from the motor when pulling away.
I find it really ironic that many people who criticised the Speedbox for the countdown, now have adopted a voluntary countdown procedure with the Volspeed, under the impression that this will prevent an error code.
I have a friend who fitted a speedbox to his Gen4 motor on his Radon bike...and having lots of problems. After a few hundred kilometers, from time to time, the motor only would allow him to drive in eco mode ?. He is now planning on buying a badass box.
I use Eplus wth positive result, so far 3500km with the chip without problem.
The only problem i had in the past, that cause 504 error, was for the mavic magnet mounted, not for this wonderful chip
I've covered over 1000 miles on my stereo 160 2020 with my Volspeed fitted, no issues whatsoever I also set the speed limit pretty high and very rarely give it any countdown time. Its very easy to install and Id definitely recommend it.
I installed it with dielectric grease on all the connections to keep the water out as I ride through deep water a lot, seems to be working well so far, I haven't touched it once since installation other than hosing it off with the cover removed as it was covered in mud.
It can be corrected 3 times .
On the 4th it will shut down and only a BOSCH dealer can unlock ...
