Levo Gen 2 Upgrading the rockshox 35 Would you go fox 36 or lyrik ultimate
chrismechmaster
Newbury
Hello Everyone
I am going to upgrade the rockshox 35 fork on my Levo 2021
would you go
and stick with 160 mm or go 170 mm
many thanks stay safe everyone
170 travel means you need to be more conscious of weighting the front end to maintain grip, I found the 160 to better balanced.
Fox v Rockshox. Much of a muchness between those two. (I'd buy a Mezzer).
That particular trait depends on way more than just the fork travel alone
I've owned both the factory 36 grip2 and and 2020 Lyrik ultimates(which I've Been using for the past month).
the lyriks are half the price and just as good. In fact i'm getting more of a fun factor from the lyriks.
Would you stick with the 160 mm 51 offset ? Cheers
my lyrik is 42mm offset 160 mm travel. My fox was 51mm 160mm.
the Lyrik is more user friendly and has a lovely feel. I recommend.
the offset didn't really come into the equation when considering what fork.
The 2021 Lyrik has a different design air spring compared to the 2020 which makes it sit higher/ give more support in its initial travel, so that maybe useful for you to know as you may not need a longer travel fork.
@apac
thank you for all the help and advice very much appreciated I will have a read through that thread now Cheers
Found this one on start fitness in stock good price
42 mm offset tho ?? Not the 51
that's where I got mine. They did have a 10% off code too. In fact, I think they may have a 10% off first time purchase. All you need is a different email address if you've used them before. Try looking on their site.
Why are you so concerned about off-set?
Only because at the moment the bike came with 51 from the factory
I thought it should be kept the same ? And as it’s 29 wheels was under the impression 51 had to be used ??
Is 42 ok to use
Is 42 ok to use
thats news to me. I cannot believe there will be any perceivable difference tbh. My levo SL is 29er
The lyrix would be easier. I just had a fox 36 put on but it took months to get new end caps from specialized in order to fit the fox one on my 21 levo!
I got the lyrik 160 ultimate from start fitness
it’s on sale from around £990 down to around £700 ish
If you then use discount code EXTRA10 your get another £70 off
So your pay £629 like me ?
    676K
