Hi
Has anyone fitted a fox X2 to a 2020 Kenevo. Looking for any feedback on the shock compared to the bomber/rockshox
Cheers
What size is your Kenovo?Yes and it is an awesome upgrade specially when you have some wider shoulders like me, easy in set up and great performance
Sweet bike. How does the air shock feel compared to the old coil shock?
You are similar weight to me, what settings are you running on the X2?The coil shock missed in my eyes a bit of progression, the bike uses the stroke very easy. I also had a hard time finding the right spring for my weight. The 105kg I have isn't making this easy.
This is the main reason why I jumped to the air shock, you are way more flexable, you want it stiffer just add some air. It also builds more progression to the end of the stroke and makes the bike easier to ride.
4 clicks from zero rebound to full rebound on Highspeed reboundYou are similar weight to me, what settings are you running on the X2?
Cheers
Sound, thanks4 clicks from zero rebound to full rebound on Highspeed rebound
3 clicks from zero rebound to full rebound on Low speed rebound
5 clicks from open compression to closed compression on Highspeed compression
4 clicks from open compression to closed compression on Low speed compression
250 psi shock pressure
Sorry for the thread hijack, but a few questions on this:The front is a 29 set up with 200mm travel, rear shock is with 65mm travel instead of the 62.5
The rear makes almost 190mm of travel without issues.
do you prefer the Kenevo as a mullet?
I like the stock geometry, how close did you end up changing the geometry with this suspension set up?
I actually bought the frame only and build the bike from scratch, never had the 650 wheel in the front. I personally think the way it is build right now is awesome, the way the bike handles is great, very stable on high speed, jumps and fats cornering. On slow steep corners it isn't due to the triple crown fork. I build the bike for bikepark riding only, if there is a lift to go up I will use it. I ride mostly in Bikepark Winterberg, sometimes it is very crowded and due to this I will ride back up.Sorry for the thread hijack, but a few questions on this:
I'm interest this too. Been riding mullet mode this summer, but with original 27,5 fork.Sorry for the thread hijack, but a few questions on this:
I Just put a Fox float X2 on my S2 Kenevo for anyone who is interested .
Yes ; 230 x 65 doesnt touch my frame at full contraction .The 230x65 X2 ? Do you have a photo of it ?
