all that done, there is no water!
He would have to remove the motor to remove the batteryI assume you've taken the battery out and checked those terminals? It suggests no power is getting through, so the battery. One other possibility is try putting the battery on the charger - for some bizarre reason it could be dead flat?
Not if you know how to use an airline properly!Drying off with an airline is a big no no, All you are doing is pushing water into and past seals. If you need to dry, use a car drying towel. I'd take off the plugs inspect and dry any that are wet.
Just take it back.Bicycle Chain
I have taken it back, they are waiting on specialized, I just wondered if anyone out there has had similar issue so that I can help bikeshop get it sorted ASAP, was looking for constructive help really.
Mind you shop manager said if it looks like a long wait he's going to cannibalise one of the un-opened bikes to get me back on track
I'm not unduly concerned, it takes as long as it takes in these difficult times, I'm just building my leg strength back up on the clockwork instead! Mind you shop manager said if it looks like a long wait he's going to cannibalise one of the un-opened bikes to get me back on track!
And keeping your analogue bike as a backupThat's the advantage of buying your bike from a good local bike shop!
I have also some strange issue with the Vado SL (same ebike setup as my Levo SL)...The update was done a cupple day ago. After that, I was driving some nice km.Just had the update done, rode home ok, washed bike, dried with airline charged up, all ok three days later go to switch her on and NOTHING! not one single glimmer of a light!! Any ideas from the Hive Mind?
Yes, you should really hold back on the firmware updates! I still haven't updated my shimano system - latest updates have been out for a couple of months now. Looking at those updates, I realise they will improve nothing for me, so I won't apply those updates. If it was an update that would improve my walk mode, I'd want it, but I'd still wait to see if there were any problems with it. Just look at all the trouble Giant owners have had!I have also some strange issue with the Vado SL (same ebike setup as my Levo SL)...The update was done a cupple day ago. After that, I was driving some nice km.
Then yesterday: I was able to power up, but not able switching between the three modes on TCU and Remote. I did try to reset the TCU and was also removing the backup battery. Did not help. the bike was starting in the trail mode and changed immediately to off mode.
I had just motor support with Smart Control and the mission control app.
The LBS had also no fast solution....
I did a quick visit at LBS...Changing the TCU did not help....they think it could be a bad cable connection. But this make for me no sense, when Smart Control is working...we will see...Yes, you should really hold back on the firmware updates! I still haven't updated my shimano system - latest updates have been out for a couple of months now. Looking at those updates, I realise they will improve nothing for me, so I won't apply those updates. If it was an update that would improve my walk mode, I'd want it, but I'd still wait to see if there were any problems with it. Just look at all the trouble Giant owners have had!
As the great Jack Rickard said “I never met a connector I liked”
That's pretty old technologyTry picking it up a few inches and dropping.
