I didnt ask you if you worry about "what ifs". I asked you if you thought it would be acceptable if your motor died under 2000km and if you thought the motor is "still pretty good" if it prematurely dies. Maybe youre just trying to sidestep the question? The "mine works fine, ignorance is bliss" stance. Who in their right mind would invest $9000 in a bike thayt theyll get 4 months of limited use out of on a seemingly phony guarantee that they had this imaginary industry leading warrantee.
You dont read about a lot of the ones that do have problems either. You can however read of the issues with all the different motor systems and compare those numbers and figure out which system has the most problems. There's several mentions of shimano problems on the forum ,and elsewhere, and some users that have had multiple problems. In the last yeat or 2 theres been little mention of bosch problems after they made a running fix on seal issues with the gen3 a couple years ago. One ebike dealer also made note of warrantees with each motor. The shimano had failure rates far greater than bosch and the brose had failure rates far greater than the shimano. Not many yamaha failure posts. I will give brose/specialized a bit of credit as theyve been fairly up front and are working to fix it and stand behind it with additional warrantee(ill be on a wait and see with that). I like to be informed with my purchases rather than the ostrich method of purchasing. Ive been on shimano since they took market share from suntour in the 80's and figured theyd have things dialed ,and if there was a failure they have a good dealer support network. The vast dealer support network is the selling point for all the bike companies that sell bikes with shimano motors. The shimano dealer support network hasn't worked for me.. im no farther in the process than i was 2 1/2 months ago when my e8000 shit the bed
