Levo Gen 2 Chain cleaning, fastest procedure
AAAAARRRRRRGGGGGHHHHH!!!!!!!!!
WD40 is Satan's juice.
Never let it near your bike!
calm down dear :ROFLMAO:
WD40 is a water displacing solvent spray. And as such it's actually very good for purging water out of chain links and removing rust from inside the rollers. just make sure you re-lube the chain afterwards.
It's also really good stuff to use (combined with a rag) to wipe down your frame, fork legs and rims adding a little shine while simultaniously drying the bike after washing
the brand "WD40" actually make spray on degreaser too ;)
WD40 is a water displacing solvent spray. And as such it's actually very good for purging water out of chain links. just make sure you re-lube the chain afterwards.
I agree, it's also very good at diluting oils and greases.
I read somewhere that NASA wanted a product that would stop condensation forming on the outside of the Saturn 5 launcher while it was waiting to go. Apparently, the weight of the condensation was unacceptable because it would compromise launch. The original article no doubt said exactly how much extra fuel would be needed to launch the condensation into the air.
Numerous Water Dispersal products were tried before no 40 was successful. At the time, it was based upon pilchard oil. :)
washing up liquid works well. I am currently using a car detailing all purpose cleaner diluted. Also works well.
Has no one here ever heard of ACF50 or BOEshield T-9 ?
Yes. Wouldn't use either as a chain lube though
Easiest quickest way in my experience is this for the truly lazy, I have the sponge and spray and it works a treat
I unplug the battery connector, pop an allen key into a chain ring bolt, put Dawn dish soap and hot water in my Park chain cleaner, and back pedal till the chain is shiny. I do get the blue error light if I forget to unplug the battery connector, but a simple power cycle has always cleared it.
I've got that but I'm too lazy to do all that after every ride, and also there is the back pedal issue so not all that easy on a Turbo Levo
Doesn't work well at all on the Levo 2020. It creates a knock then the bike turns itself on and then it generates a motor error.
Just unplug the cover from the charger port and the motor won’t turn on.
Lift the back wheel (i.e. bike stand) and rotate it backwards and so will the chain.
Once on the bike stand you can drive it forwards. Then you don't have to unplug it and risk getting anything on the connectors and you don't bash the plug.
This, I just sling the bike on the stand
Guys, you're making it unnecessarily difficult. I myself wipe the chains clean with an old bath towel piece and add good chain oil. Such as Dry Finishline or Muc-Off Dry. Shift gears up and down a few times. Then wait a moment and wipe off any excess oils
Has done so for 30 years and the current chains have lasted more than 1000 km
Yep, easy peasy
What is a good test that the chain is clean enough ?
The method I have always used is, if you can touch it with your hand and your hand looks clean afterwards
Spray wd40 on and leave for about 5 mins, then use paraffin with either a toothbrush or dedicated chain cleaner. Wipe with rag or old towel, re oil and its as good as new. I use this method with all my enduro bikes and big KTM's for many many years.
Don't be fooled with all these fancy expensive chain cleaners.
clean streak dry degreaser in chain cleaner spun forward-no water, no residue , drys in seconds
    Join 43,192
