I have one of these.
It is great for the small jobs, in fact I hardly use my proper bike stand any more since I purchased this.
You just need to make sure you are on a nice flat surface which you should be in your garage and workshop.
It is just on the odd occasion where I tried to use it out on the trail next to the car on a slope it didnt work too well for obvious reasons...
It is very easy to mount the bike on it. Just line it up with the frame stays and Bobs your uncle
Excuse the state of the bike, I was out on a ride this morning before work and havent had a chance to clean it yet
Good for oiling the chain
Good for checking tyre pressures before a ride
Good for indexing gears
Good for tighening up bolts
Good for bleeding the brakes
Good for replacing the chain
Good for washing and polishing
Good for fitting mudguards
Good for removing the motor (Although you need to remember to loosen the crank arm bolts first as undoing a mega torqued crank arm can flex this stand)
NOT GOOD for sitting on your bike while it is on this stand
Under £20 Bargain!!!
IBERA IB-ST2 Bike Stand Easy Utility | Bike Stands & Wall mounts Shop
