Levo Gen 2 Head Tube Exit Port (2mm hex bolt)
Mattwilko92
Staffordshire, UK
Hello all,
Sadly the 2mm hex bolt on the head tube exit port is rounder off on my 2019 Levo Carbon.
Does anyone know how or where i can obtain a new bolt?
Thanks in advance.
I would think your LBS can order one (at a ridiculous price) from Specialized. Other than that McMaster or MetricScrews.us have just about any screw imaginable.
Cheers, i managed to drill it out today using left handed drill bits. Ordered some m2 x 6mm countersunk hex bolts which will hopefully do the trick.
are you referring to the headset cap bolt? If so just order an new headset cap which usually comes complete with bolt and star nut.
Hey I managed to strip 1 of those M2 hex bolts holding the port in place - did the M2 x 6mm countersunk hex bolts you ordered work out for you? Do you recall where you got them? Thanks!
    672K
