Motor and mud grinding noise
dpeart
US
I recently bought a 2027 Raleigh Tokul IE.
Many places I ride are wet. I've noticed that mud and leaves get stuck between the front chaining guard and between the chaining and the motor bearing.
It seems that the chains brings the debri up and it gets packed in. This make a very unpleasant grinding noise. At first I thought my derailleur was misaligned.
Now I stop periodically and use my water bottle and a stick to clean it out.
Is this normal? I read a thread on here about removing the chairing guard, but wasn't sure if I have to buy something to replace it with.
I also saw something called a mudring 2 . Unfortunately I only read English so I could only look at pictures.
Looking for advice
David
A 2027? You have to tell me where you got that time machine
Hi David.
Removing the original equipment sprocket and guard will almost certainly solve your current issue.
Firstly you will require a replacement sprocket that does not have the guard. I have found Connex to be the most durable, but if you are running an SRAM set up, their narrow wide front EX1 sprocket is superb, and I wouldn't change away.
Next up is a locking ring and O ring, which weirdly many people choose to leave out. I don't.
Being a plus size bike, you will also require either 2mm or 2.5mm off set spacer. Sticking my neck out, I'm going to say opt for the 2mm version.
Finally, you will also require a Bosch locking ring spider-tool.This is one tool that is worth investing in, and you will use it time and time again.
I've been able to find everything except for the spacer at this store: Bike Shop | Bike-Discount: Onlineshop mit Bestpreis-Garantie
Being in the states I've not found anything local. Anyone heard of this store? they appear to have an unbelievable price on some tires as well. Figure I might as well buy a boat load, as I'm paying shipping.
Still looking for a spacer.
thanks,
david
Its a highly recommended online store in europe and you can trust them no problem.
Karsten
Agreed, I have used these guys a number of times before and have always had good service from them (y)
For spacers this is all I found:
Gates Lockring Spacer Kit for Bosch Gen2
it says you don't use the o-ring with this lockring and spacer kit, but it is the only spacer kit I've found.
Unfortionately this store doesn't sell the bearing service kit.
hmm $80 to ship to me. Have you used the GAtes lockring I linked to above? It has spacers and I can get it from the same shop so shipping is reasonable. Its a shame you can't buy any of these Bosch parts here in the US. I could call the authorized store, maybe they can get them.
I have only used the Bosch original equipment spacers, but they should be something that any dealer that sells Bosch powered bikes should easily be able to obtain.
Failing that, perhaps drop a line to Bosch USA. I'm sure that they must be able to help.
Was able to find a shop here in the US to sell me the parts. They only had the 2mm spacer from a SRAM EX1 chainring so they sold me a Bosch 18T chainring and included the spacer. I didn't need the SRAM chainring. Got the lockring tool from them as well.
thanks for the help
That's brilliant news. :)
I have a few 2mm spacers knocking about, and hadn't realised that they were such a problem to get.
