Kenevo Gen1 Kenevo 2019 (pre dual crown ) what head bearings ?
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Hi like many owners of Kenevo the head bearings are not good ,so for the umpteenth time what’s the best bearing you recommend ? Cheers folks .
Double check but these ones should be right.
SPECIALIZED INTEGRATED HEADSET BEARING ONLY,CAMPY STYLE,41.8 X 30.5 X 8MM THICK ACB 45X45
Sorry I think that's the original.
You could have a look at these although I don't know about their durability.
ABI 1 1/8" 45 x 45 Degree Stainless Steel Angular Contact Bearing 30.5mm ID x 41.8mm OD x 8mm wide
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Try the manual?
Nobody reads the manual :)
Of course you're right - 4.3 Headset - although I think the OP was asking about other more durable options for bearing replacements.
The headset uses a 1 1/8” (41.8mm x 30.5 x 8mm, 45x45°) Campagnolo Standard compatible upper bearing and a 1.5” (52mm x 40 x 7mm, 45x45°) lower bearing. Ensure that replacement bearings are compatible with the Specialized headset specification. No tools are needed for installation or removal of both bearings. Grease bearing surfaces before installation.
It highlights the need for an exploded view diagram with all bearings, fasteners & consumables. That would be very helpful.
526K
