Levo SL Gen 1 Levo SL fork tokens
chinesederek
Windermere
I wondering how many tokens come as standard in the Levo SL Fox 34 Performance fork? I’ve not got the right sized socket to take the top cap off to check. I can only assume that people on here Ha e already done this many times so please let me have your knowledge.
... I’ve not got the right sized socket to take the top cap off to check.
It’s best to use a 26mm spanner due to how shallow the bolt cap is.
If you do use a socket be sure to grind off any chamfer so that it will sit flush on the cap and not damage the soft aluminum.
Fork comes with no spacers as standard. I fitted 2 and it improved but felt harsher at lower speeds. Recommend a 26mm spanner or flat ground socket. Don't use a standard socket. Just fitted an MRP ramp control. Not tried it yet but theory is the extra air volume gives the better low speed response.
I eventually got into my fork I’m my SL Expert X Large - 3 x tokens in the fork. I’ve removed one and I am now getting much more fork travel and harsh bottom outs.
Apologies meant to state mine is a comp large size
    Join 43,189
