Have you read the New Lyrik's owners manual?
Someone kindly turned into a handy animated user video guide
I have fox 36. 160 factory. And lyric rc2 160 in 42 mm offset fox is standard 51mm going Ty try both to compare I will post soon[/QUOT
Which offset did you like better? I am looking for used Lyric and there is a 42 offset for sale on Pink bike.
Yep that's why I peeled the sticker off the stock Sektor RL and put the fork on my hardtail.No. The difference between normal and ebike specific forks is only in a "Add 10 PSI" sticker.
It is in very simple terms to shorten or lengthen the wheel base to the best of my knowledge. I stand corrected if this is incorrect.I’ve just bitten the bullet and ordered a 160mm lyrik ultimate in black standard 51mm offset to change our from the standard revelation fork that doesn’t seem to work... just out of curiosity what is the advantage or disadvantage of the 42mm offset?
Yeah. keep standingIt is in very simple terms to shorten or lengthen the wheel base to the best of my knowledge. I stand corrected if this is incorrect.
on different bikes I assume?i got 42 and 51 mm , the 42 has a sharper feel to steering ,and more stable at speed , but a lot harder at low speed turns switchbacks etc , i was thinking about increasing the 42m to 160mm travel hoping it would put the handling somewhere in between but not sure it would !
no ive been swaping them on and off my levo both lyrik 150mm only difference is one charger and other charger 2on different bikes I assume?
wat type of coil you have?I’ve put a 2019 180mm rc2 lyrik on my 2018 Levo and it rides sweet. I’m an aggressive rider and weigh just shy of 100kg kitted up. I’ve got 2 tokens installed. The handling is sharp and responsive and overall I’m really really impressed with them ??
What damping settings? What damper? Did you use all the travel at appropriate times?rode the bike today with 2 tokens and 90 PSI
Weight 77KG
A few times hit the fork limit and blew all the travel
Anyone got any ideas
Y don´t you use 170mm?2.1 damper on a 2021
Used most of travel at appropriate times
