Rockshox through shaft shock question for those that have them
pgtips
Somerset
Can someone with the RE:aktiv Thru Shaft on their Rails could tell me is the bottom mount looks like this i.e off centre. It just looks odd when looking at the pictures.
Looking at my options on upgrading my shock on my Rail 7.
Many thanks in advance (y)
Anyone guys? Just a quick look and see if your Thru Shaft bottom bracket on your Trek looks like the one on the picture?
Would be a great help guys, thanks (y)
Just looked at mine, it's hard to tell in situ, but I don't think it's as off set as that one you pictured.
Thanks Paul. it does loo like is longer on the non drive side? yes difficult to tell.
Maybe a tad, but not as pronounced as your picture
Bummer! I wonder which model Trek this fit then!
Got to admit, that looks like the right one.
Maybe the longer portion of the eyelet actually slots in to the frame a bit?
The frame mounting does look thicker on one side
No on second thoughts can't see how that would work, as there's not enough room to put it in on the angle.
Trek slash also has that shock, they might have the bigger offset
Thank Paul. I give that one a miss then mate (y)
This is from a Trek Remedy, and it looks to be the same as yours.
    675K
