Need a new dropper post for 2019 Levo!
Andy A
North Yorkshire
Hi guys my wife has the medium size 2019 Levo Comp and the dropper post is so hard to push down so is there anything I can do to adjust it or do I replace it?
If so what with as I don't want to go mad as some of them are so expensive, I think it is 34.9mm diameter so anyone recommend one to get?
OneUp Components makes a very nice seat post for $200. Get the wolf tooth easy action seat dropper for the seat post. My favorite is the Sram AXS seat post but it's quite a bit more.
PNW makes a really good post. I just installed one on my 2020 Levo to replace the crappy Specialized IRC that came on the bike. I have Fox Factory on my other bikes but much prefer the PNW with the Loam Lever. The best levers I have ever used!
My X-fusion Manic does that on my 2020 Comp. User manual advises regular top seal servicing. Undo the threaded cap at the top of the lower tube, mine was really stiff and needed a plumbers wrench, I wrapped a piece of inner tube round it. clean the tube and especially the inside of the cap, there is an o ring that sometimes gets stuck inside the cap. Press some light grease, I use SRAM Butter, into the top of the bottom tube and cycle the post a few times. Reassemble.
Thanks for this, which post have you got as mine is 34.9mm diameter and I can't see one on their site at that diameter they are all less than that?
Andy
You can also install posts with smaller diameter as is your seat tube diameter, but you need to use proper shim. Personally I like to avoid using shims.
I agree I will stick to the proper diameter ?
Andy
The Bachelor post is 34.9. Also check out the Loam Dropper Lever. I was able to fit a 34.9mm by 170mm rise on my size large 2020 Levo expert. The post will go all the way down in the frame and yet with 170 mm rise I get really good extension for when I’m pedaling on the flats or up hills.
Andy
Thanks for that but crikey that is an expensive post isn't it ??
Anybody knows what is max travel dropper post which will fit in L-size frame (Levo 19/20 ALU)?
Brand X with a shim. I had one on my Cube 2.5 years no issues, no servicing just kept going and at less than £90 to buy its a simple no fuss solution
If it’s a Specialized IRCC post.
Let the air out of it from the valve under the front of the seat.
Unscrew the seat post collar anticlockwise and slide up the post. This may require a rubber strap wrench to undo.
Pull up on seat and push the dropper lever at the same time. This will release the inner from the outer post.
Pull off all the o-rings, collars and brass key ways off the inner post. Do not remove the dust seal from the collar.
Clean everything and reinstall o-rings ect. Re-grease with rubber compatible grease, or ideally SRAM butter.
Wipe all grease from outer post and re-grease.
Insert inner post into outer post. Push down slightly whilst activating dropper leaver.
Refit collar and screw tight. This should be air tight.
Air up post to 15psi max and test. A digital shock pump is ideal to do this. You can adjust the pressure from 5-15psi to adjust the speed of the post.
Wow thanks for that but is it easy enough to do as I am no mechanic ?
Yeah it’s so easy. Just take photos as you take o rings ect off the inner shaft. And put everything in order on the bench.
I did do a thread on it once with pics on here. Will see if I can find it.
I have been known to service the post within 5 min before a ride ?
Inspect the cable mechanism ,make sure there isn't a kink somewhere and get the post rebuilt if someone is available with abilities and experience fixing them. It's probably repairable .
You could get it serviced for £35 and it will be like new... X-Fusion Servicing - Upgrade Bikes
There is an updated seal for these 34.9 Command Posts. I too own a Levo Expert 2019 and had issues with mine, apparently air passes a seal and you get a negative air chamber. Approx 1 year ago I had was told about this by the suspension expert Juergen at Specialized UK in Chessington. He very kindly offered to service the post for me FOC and it's been perfect ever since, I still add a quick small spray of GT85 to the stanchion before heading other wise the head seal grips to much when it's dry and can this slow the return. I run 85 psi.
I now believe PLUSH are the service agent for the Command posts and they serviced a 30.9mm on my wifes Levo Carbon Comp 2018 last summer and thats been great too. Please note: these 30.9mm posts run at a much lower pressure... 18 psi is all you'll need in these and a light coat of GT85 on the stanchion before each ride. Despite what everyone says, I have love the command post and the fast speed it returns to full height. Use your weight to bring it up at a controlled speed if need be.
I would send it to PLUSH Suspension in UK. Book it in online, its approx £67 if I remember.
pretty sure the 2019 Comp (both alu and carbon) use Xfusion Manic so all this stuff about how to service Command posts is going to be rather confusing to the OP. I would suggest contacting Upgrade Bikes, the importer/distributor, as mentioned a couple of posts above.
Or give the upper seal a service as advised in the user manual and which I described at the beginning of this thread.
Hi Kenny I will see if I have the user manual for it and hopefully a numpty like myself can do it without messing it up :)
Yes, manual says you should regrease seal head every month, it's very easy 5 min job, so I wouldn't even call this a service job, but rather regular maintanence, like oiling the chain ... But even more important is to clean the seat post stanchion and outside of the seal head after EVERY ride ...
    Join 43,242
