HampshireSam
Could someone link me to the correct chainring for my 2020 esommet.
Thought this may be the case, but wanted to be sure.
Alloy wont last long and will result in chain suck as it wears and catches the chain, i found this out after I toasted one of those rings in the space of a single ride after repeat climbs of a huge hill in turbo mode on the 46T granny gear.
My recommendation is to go with the Praxis Steel E--ring, 36-7001 is the part number. Perfect fit on the E8000. Cheap. Performing flawlessly so far.
It is neither unfortunately. I usually get everything online but fucked if i could get a hold of one of these!
Try your local bike shop... giant and specialized definitely both deal with praxis. I had no problem having one ordered in from a specialized dealer nearby. Was only approx $45-50
Do you find yourself further up the cassette on descents? That's what I'm hoping to achieve. This and STunlocker are the only 2 things I will have done to the bike so far...Thank @Gary he told me ?. I've been running a cheopo NW 36t like in link for months with zero issue and hundreds of miles. Best buy I've made for the bike, after STunlock of course ?
Thanks @Gary
It's possible!I've done 600 miles with some serious climbs and aggressive riding and I'm not even showing wear on mine. I guess you got a bad one...
On mine I run 36t up front, 11-42 out back, and 118 links
