Clicking from motor mounts.
Levo-Lon
Uk
New ( 3months old). Levo comp carbon.
I think it's the motor mounts ? I've greased and tightened the seat and post.
I'm thinking it a case of loosen and re-torque the motor boots.
Anyone had this ,Fix ? The only bolt that's been undone was the chain guide one as that undid itself...
I've checked everything so I'm pretty sure it's the mounts
Lube? Owners manual is clear on this, clean, Loctite blue on the threads, grease on the shaft. Remember there are 6 bolts, 2 are almost hidden by the chain stays and cables, I've had to undo the top shock bolt allow the suspension to be moved so I can get at these. By the way the owner's manual said Loctite for this shock bolt, the Retailer's work book doesn't mention it. Next time no Loctite.
Sorted..
Done the bolts and after a try I think it was the headset spacers after a lot of searching, I know lol..bloody sounds and frames..
Sorted..
Tracking down those annoying noises is always a chore, glad you found it.
:giggle:. Battery creaking :LOL:. ... Where's the bang your head emoji??
I guess it doesn't like being done up tight.
He mine was the seat clamp and handlebars some people had problems with the plastic covers on the motor
I’m sure it’s the motor mount bolts. I’ve had the best luck running the torque value lighter than the manual specifies on a ‘19 Levo Expert. Very frustrating.
New motor fitted to my 2020 Levo and the mounts click....very annoying. Pulled all the suspension linkages and greased, cleaned and refitted seat and seatpost, cleaned and refitted forks/front end, pedals checked on another bike, drivetrain clean and lubed, cables routing checked...motor mounts it is.
