Levo SL Gen 1 Let’s see you Levo SL cables and hose routing
chinesederek
Windermere
Evening
I’ve been looking at the cable and hose routes around the front end of my new Levo SL Expert and I can’t help thinking that there must be a better solution.
The main problem for me, being a UK rider is that the rear brake is in the left and the hose is routed through the left side port (when viewed from on the bike). This leads to a very pronounced tight bend in the brake hose. Anyone running their left rear brake hose via the right hand port?
Show me what you got.
Having just stripped a Levo SL down to practically nothing because my brake route is blocked, I can tell you that those 4 holes in the frame are actually fully routed sleeves to the specific locations.
I run an AXS shifter so have no shifter cable, but if you push a brake hose into the shifter slot, it miraculously appears at the shifter exit on the rear triangle.
You can’t pick and choose which hole to use I’m afraid.
First thing I noticed when riding a demo SL was how bad the cable for rear brake was routed. Bugger you can’t change it. It was worse once I’d moved the brake lever in board to stop the dropper post trigger hitting my hand while riding. Shortening the cable would of been my only option then?
Ooohhh, that's why my brake line went through the frame so easily !! :ROFLMAO:
I thought a miracle had happened. I couldn't believe my eyes when the brake line suddenly appeared in the right place. :eek: I really thought, you lucky bastard !!
    676K
