kylnman
Walk mode doesn't seem to have any function. Certainly doesn't help me up the odd 20+% grade in any perceivable way.
Mine doesn’t seem to do anything either.. bikes only 2 weeks old.. few times I’ve tried it, I felt zero assistance.Well walk mode works great on my Shimano powered Focus and Canyon bikes.
Press the down button once to select walk and again to engage it.
Don't apply any forward pressure yourself as this powers the motor down.
The higher the gear you select, the faster your bike propels itself.
If things still don't work then it's in the box and back to YT but I'm pretty sure that we are looking at operator error here.
I have... doesn’t do jack shittry it again and make sure you have a small cog selected, keep pressing the mode button to keep the motor spinning, don't push the bike, just hold on the bar
Can you try it on the bike stand? I used it to spin the chain while lubing couple times - used a rubber band to keep mode button pressed. If it fails, call the seller
Be careful not to put your fingers near any moving parts though!
Sounds brokenI have... doesn’t do jack shit
Just don’t walk much, prefer riding.
You called it... just been so stoked to ride I’ve beenOr just read what I told him in post 8.
There is a know issue where manufacturer's do enter the correct "motor angle" and it is supposed to effect walk mode for some reason. My walk mode is shit even in a hard gear. It's very jerky OFF then ON lightly. Steps e8000 walk mode - EMTB Forums
I used it yesterday on the trail... sure it works but doesn’t work... not enough power to help when you need it.. works on flat ground!!
Hmm! something not right then, walking up a steep bank mine will easily spin the back wheel.
Yes it will work on gradients steeper than you can ride.
when working properly it simply opereates the motor to turn the chainring (at a set speed) when the shift button is held down.
Rhis is why gearing matters.
So choose an appropriated gear or it'll be either far too slow or struggle to maintain rear wheel grip.
For me the whole thing is a gimmick. If I come across a gradient/technical section on a climb I can't ride up I still don't ever bother using it as I simply can't be arsed with the faff of changing into a higher gear first when i'm prefectly fit/strong/capable enough to push a bike up a hill without assistance. YMMV
