Has anyone else out there had issues with suspension set up? the sag on mine is set correct but out on the trails the bike is so harsh and out of control its actually dangerous. came off on the first ride 10mins after setting off, I adjusted the air pressure and it made a difference but now im smashing pedals and its still bone rattlingly hard. tubeless set up 28psi rear and 25psi front. really considering taking the fox forks off.
Hi Dave .I feel you need to set the suspension up correctly . I think your risking damage to the rear wheel and frame with pack down and harsh bottom out . The energy from harsh bottom has to go somewhere and rims are usually the place it goes sometimes the frame .
I hope you don't mind me offering advice on air suspension as I have many years experience with Fox and RS air forks , fox X2 float and CCDB air on VVP DH and trail bikes . Ill be buying a the Decoy Pro once the AU sight come back online because of the suspension tun ability and performance .
Air shocks and forks have the benefit of tuning progression primarily firming up the mid stroke by using tokens , the token do effect the very very last end of the stroke but primarily they effect the mid stroke / the platform . By using tokens you effects the mid stroke while + - dampening fine tunes the air suspensions behaviour at the beginning and end of the stroke .
I personally feel it's best to set the fork up first , but most importantly the rear shock and rear wheel needs to be protected against damage of incorrect setup while setting up the forks/ bike correctly .
This is how I would set the bike up starting with the addition of token instal .( There are great videos on Youtube to help with the token install to help if you'r un familiar or need a refresher .)
First I would protect the rear shock , add all volume spacers to the rear shock and have all dampening to recommended settings set desired/ factory sag . By doing this you shouldn't bottom the bike out harshly .
Start the fork set up and concentrate on the fork setup , a poorly setup fork is dangerous.
Open the fork up and add a token or if a heavy ridder add two tokens . Inflate fork too desired sag with recommended dampening . Cautiously ride the bike slowly on some dirt or burns and see if you are getting a reasonable amount of support/ platform and the forks are not diving .
Once you feel the forks are offering safe support you will start to push the bike and will start to get a feel for the rear of the bike and be able to start diagnosing what the rear shock is doing.
The rear shock is where you start working back from a starting point ( max bands factory dampening sag ) , If the rear shock feels too progressive to go through the travel , remove a token/ band from the rear shock and this will make the shock more progressive/ blow through its travel .
Once you have. a safe starting point where you and the bike wont get damaged you can then fine tune the suspension with dampening .
Im sorry if Im going over thing you know , and please feel free to ask any question .
All the best .
