Ladybower Loop
Are you just visiting or do you ride regularly there ? I would have joined you but got my daughter for the weekend. Great place to ride and you need to check out the Ladybower Inn when you've finished .
Personally I've only ridden Ladybower once - it's completely different to what is around me for sure, so maybe that's why I try and return as often as I can, to the area. Plus the guys I ride with, are a decent set of lads. As the Peaks are over 3 hours from my home, I don't usually hang around for a post ride pint/food, as I'm usually heading off, to work a night shift...Although, I may make use of their carpark Friday night, to sleepover, depending on what time I get there (y)
