New Cassette
nickthebee
henley
Hi i have a 2019 specialized levo T any one know a good replacement rear Cassette any links would be much apresiated
Just fitted a 11-46 Sunrace off amazon on my levo. About 60 quid and brill for the price, red aluminium carrier.
I also use a 11-46 setup on mine. A tad more expensive than what @MarkH has but I run with a SunRace cassette and got it from Slam69 here in black. The black cassette with red internals is a nice look and matches my levo nicely :)
Cheers Nick. I actually work with someone who gets me parts at a discount from slam69 which is why I posted their link (although its a fair bit more money). I'll save that ebay link anyhow because it'll come in handy one day :D
if you fancy some henley trails message me I'm often out alone the riding around henley is amazing just need to get my mates to buy an e bike
I use a sunrace 11-46 cassette on my entry level 2019 levo works perfectly with the nx derailer much better than the cheapo sram cassette that came with the bike and lighter as well
what nx ? did it work better
The sram nx cassette fits on a shimano freehub not a sram xd driver. The cassette is very heavy individual steel rings. The sunrace rings are mostly mounted on ali carriers and is a much lighter cassette with in my opinion better teeth profiles
They do 11-42 11-46 and 11-50 cassettes all fittingnon Shimano freehubs
ahhh so i have have the sunrise coming are you saying it won't plug and play
it will if your freehub is shimano what cassette are you replacing? only the sram pg-1130 fits a shimano freehub all others in that range are on xd drivers
I have a PG-1230, all my research suggests that it too isn't on XD driver. Did you mean the whole PG-xxxx range is all on a shimano freehub?
No i just meant the 1130 which is nx. as far as i know the higher spec ones like gx and xo are on xd drivers
Looks like the pg 1230 which is nx eagle also fits the shimano freehub
I'm also thinking about changing stock 11-42t cassette for 11-46t or 11-50t, does any1 have info how longer the chain should be for using bigger 46 or 50t rings?
EDIT: Nevermind, after posting this I found this review which clearly says I cannot run such big cogs with Sram GX 1x11 derailleur, so I have to scrap this idea for now ...
I have had absolutely no issues running a 11-46 cassette on a GX rear mech.
Karsten
Karsten
I see that max nr. of teeth GX 1x11 is willing to shift is 49... Do you use Sunrace cassette?
Yes as a matter of fact I did initially but it’s a POS. Very soft and smaller sprockets are like butter and bends easily. Also, shifting is noisy and not very precise. Buy a Deore cassette instead is my recommendation.
Karsten
SLX M7000 11speed cassettes are way better VFM with almost exactly the same performance.
especially if you can find an older model with just the one Alu sprocket.
there's a slight <50g weight difference (depending on chosen ratio/alu sprocket config)
If you can cope with an 11-40 they're often avaialble as cheap as £30
    676K
