Fox Float X2: anyone have opinions?
Albuht
CA
Have a 2019 levo and I’m upgrading the rear shock. Anyone have experience with the Float X2 (not the DPX2).
Based on my searches it seems people are favoring the coil. I love coil but I’m wondering why people are going coil over air as well. The adjustability of air is a big pro for me as this is my first ebike and I’m not sure I’m going to get the same pop as a regular MTB with coil since the ebike is heavier.
Also, I’m guessing the levo has the same or similar leverage curve as the normal stumpjumper so it will probably be more linear?
Thanks for the repose guys!
Mate ran a x2 on his Patrol, was very plush
I’ve got the X2 on my Meta Power 29, great small bump sensitivity and also loves the big hits. I’m very very happy.
Thanks for all the input, everyone. Sorry guys, my fault. Shop thought I wanted a DPX2. Decided to go with a DHX2 210x55. It's a bit more travel and tolerances should be good. Gonna see if Fox has these available.
Anyone else running a 210x55?
I've been considering this one :Fox FLOAT DPX2 3Pos-Adj 210x52.5 Trek Fuel EX, 2020
It's the right dimensions for my 2019 Levo comp. Has anyone installed this part #?
My 910-20-609 Fox Racing Shox 2019 Fox Factory 36 Float E-Bike+ 29" Fork Grip 2 Tapered arrives today! Looking forward to installing it tomorrow eve and giving it a ride.
I'm finding my RockShox Revelation is not plush enough on long descents.
Edit...and It's installed. Taking it out later today
I’ve got a similar setup up front on my Meta with a 36 Factory, Fit 4, 150mm, eBike specific fork. It’s burley beast and I’m loving it.
It’s running the Float X2 Factory on the rear, it’s more of a heavy hitter (in performance and design) and I would suggest more suited to an eBike.
I do run the DPX2 on my conventional trail bike, it’s a lovely bit of kit but I can see why the Float has been spec’d on my eBike. It’s worth noting the Float is slightly heavier, harder to set up and service.
i have a X2 on my manual yeti, and a ohlins TTX on my levo. While the X2 is a great shock, the coil for the levo transformed the bike.
It greatly helps with uphill technical climbs, as the coil squats the rear and delivers the power much better
also helps with landings due to the heavy weight of the levo
Did you go for the 210x55. And how does i Feel.
When fitting a X2 to a Levo do you need a new mounting kit or can you use the one already fitted on the Levo's standard shock?
Also if you run the X2 210 x55 do you have to run the flip chip in the high position or can it be run in the low position?
Either position is fine... I reused my hardware. Had fox Dps already on it... I believe the size is 6x20mm
I have the x2 on my enduro and I think it is great. Butter smooth.
I would have put one on my 2018 Levo but I don't think it was available so I went with the dps
Cheers, i have a DPS on my Expert so its a simple swap then
Ive also got a spare frame with a FOX Float X2 fitted that i was going to swap over but its
230x60 so wont fit
Good advice! Do you know if the X2 will fit inside the 2019/20 Levo Frame? Is there enough tolerance for the large aircan?
Ddc6284
When you used your existing mounting kit from your DPS shock did you not use the two black spacers?
I cant get my X2 to fit using the two black spacers, the X2's eye looks to be wider than the Levo expert's DPS shock's eye
Ive just fitted the two bushings and rubber o rings and the alloy centre shaft and the whole assembly just slides in, no room to fit the black spacers
Ddc6284
@escrs did you manage to make this work please?
Yes i just fitted the shock without the two black spacers and all is fine so far
I've always preferred coils on my bikes, but I'm really considering putting an X2 on my '20 Kenevo, as the linkage rate they have on these things is NOT conducive to popping off stuff. Trying to pop off rocks, roots etc. feels like trying to jump a semi
I put an X2 on my '18 Kenevo for a minute(sarcasm for a week), and right away I didn't like its initial stroke stiffness. Obviously coils are softer in the initial part of their stroke, but air shocks tend to lack mid-stroke support. If the linkage leverage curve for the bike you have looks like a frown(the 'apex' of the frown means the linkage has weak mid-stroke support, ), you typically would wanna stay away from an air shock
Try this Proimpact kit to boost mid-stroke support
I blew the fuck outta the stock marzocchi POS(bent the fricken shaft, and broke the clip) shock today, and couldn't find a DHx2 anywhere that could get it to me by tomorrow. I don't know what made me think of it, but I looked up the size of the X2 on my Firebird(Pivot) 29", and sumbitch the thing fit.
I've now cannibalized both ends of the Pivot for my Kenevo.
I'm gonna ride on the X2 tomorrow on some pretty rocky, bomb-holed, steep runs. I really prefer having traction on these runs cuz of all the rocks(a lot have broken away), so we'll see how well the X2 sticks the tire to the ground.
I'll report back
230x60 so wont fit
Shoot!! I am on the same situation, was hoping to use the shock from my spectral:on (230x60) :(
Seriously, it is getting to be another fad...Air without doubt has the best quick tuneabilty and unless you are a serious racer is perfectly good for all trails...the coil has some benefits but you need the exact weighted spring... others would argue to the death that they are better, good set-up and personal choice is all you need. The Fox Float X2 is a brilliant shock and I've had them on three enduro bikes and have been for me just as good as any coil...big hucks, drops, jumps and downhill.
I have the X2 on my '20 Levo with the 55 stroke.
140lb, aggressive rider that likes to plow into everything and jump anything, but jumps on our trails arent much of anything larger than your typical man made jumps made out of fallen trees/logs.
230psi, 10 clicks of HSC, and I still blow through the stroke incredibly easy. There is ZERO mid-stroke support. The shock has 3 volume spacers in it now, and I will add one more since it only accepts 4, but I will likely need to send the shock in for a re-shim. I need to add more air, but my Fox shock pump is very granular above 230psi and trying to do small increments is very difficult.
Any person above my body weight and is semi-aggressive I assume would have a difficult time using the stock tune from the shelf shocks.
That doesn't sound right! Granted I only have the DPX2 but I'm 175 on a 19 levo. I use 90% of my travel riding aggressive but never bottom out. I'm only running 1 volume spacer and compression settings are full open. Unless we have different definitions of aggressive ?
    Join 43,204
