Levo Gen 2 Specialized Turbo Levo and Kenevo Weight
That table is for the old Levo
If there's enough interest I'll figure out how to make mine available...View attachment 13035
Of the weight saving upgrades here:
The Bars & Cassette are standout easy wins if you want to drop weight with savings of 1.7 & 1.8 grams per £.
Worth considering dropping to 10 speed. I'm running Shimano XT 11-36 cassette with Zee Mech. The cassette is 340g, and Zee Mech is 280grams. That's a 234g saving to be had for under £100 if you can live with 10 speed.
Personally I never need the dinner plate, even for super steep stuff I find that it spins out too easily.
Just picked up my Levo S-Works size M, added my own composite flat pedals, and total weight is 20.85 KGs (or 46lbs for you old fashioned types). Strangely I think that is lighter than Spesh list it at, as in my memory they said 20.7KGs without pedals.
This weight includes tubes, SWAT tool, bottle cage, etc.
I think, if you've chosen a Kenevo, you've thrown any and all ideas of lightness out of the window.
No matter what you do to it, you are still riding the heaviest mountain bike you have ever, or will ever ride :)
Personally coming from a motorcycle off road background I prefer something underneath me like a Kenevo
Most mountainbikes I find are too light giving minimal feedback downhill
Is there a weight table for the 2020 models?
In different Kenevo videos i watched the specialized guys said, the 2020 Kenevo has the same weight than the 2019 model. 1 kg less from the Mag-Motor and the lighter frame-design, but 1 kg more from the fork (speaking of the big one) and bigger battery. If you find an old weight-table, it could still be close to the new model.
I am mainly interested in the 2020 levo comp weight.
My 2020 medium Levo has a sticker on it saying, amongst other stuff, 22kg
Hi is the Cassette you change it to a xg1150 as i can not find a pg 1150. Cheers
Yes, My 2020 Levo Comp in size L has also a sticker stating 22kg ...
2020 Kenevo Expert in S5 weight in at 24.5 KG without pedals on my scale.
What is the weight on the 700WH battery?
Looking on options to transport bike on roof rack with Thule ProRide (with battery removed) when I decide to get the bike, or remove wheels and try to fit bike in car (Volkswagen Up)
2019 Carbon Comp, 500wh, carbon fat bars, Industry 9 35mm stem, RaceFace pedals, slip on grips, Tubeless, no Swat tool or stem holder and I am at 47 pounds.
Maybe the factory weighs theirs with the battery empty to get the lower numbers?
2019 Turbo Levo Carbon Expert 48.0 pounds
With pedals
Carbon wheels
Cushcore
Magura MT 7 brakes.
Push spring and valve upgraded on Roxshock Pike (amazing)
My turbo levo Comp 2020, size S as purchased. Added spd shimano xt and another saddle, fizik rondine (309g).
I’ve managed to get my base level Levo down to 20.9kg and could still shave off another 3-400gm without compromise.
The only oem parts are the frame, battery, motor etc... all else has been swapped out.
I’ve even managed to up the travel to 170mm front and rear. Still running maxxis minions, 27.5 rear wheel, it’s a beast!
My 2019 Turbo Levo Expert weighs in at 19.85kg (43.76 lbs) including the SWAT tool, water bottle cage and pedals. I've done a few things to it, including going from a 700wh battery to a 500wh model. I've also swapped out the wheels for some Nobl TR37 rims, with Industry Nine 1-1 hubs, CX-Ray spokes and alloy nipples. Other swaps include a Sram XX1 10-42 cassette, Praxis carbon crank arms, Praxis 30T alloy chainring, Enve M6 handlebars 780mm width, Syntace Megaforce 2 40mm stem, Rockshox Stealth front axle, ESI silicone grips, Maxxis DHF 2.6 and DHRII 2.3, and Specialized Phenom Pro saddle.
My 2019 Turbo Levo Expert weighs in at 19.85kg (43.76 lbs) including the SWAT tool, water bottle cage and pedals. I've done a few things to it, including going from a 700wh battery to a 500wh model. I've also swapped out the wheels for some Nobl TR37 rims, with Industry Nine 1-1 hubs, CX-Ray spokes and alloy nipples. Other swaps include a Sram XX1 10-42 cassette, Praxis carbon crank arms, Praxis 30T alloy chainring, Enve M6 handlebars 780mm width, Syntace Megaforce 2 40mm stem, Rockshox Stealth front axle, ESI silicone grips, Maxxis DHF 2.6 and DHRII 2.3, and Specialized Phenom Pro saddle. View attachment 35636
I Like this build . Under 20 kgs . Nice work
New 2021 Turbo Levo Comp, Small frame, 700 battery, including bottle cage, tool, and Specialized aluminum pedals: 23.40 kilos (51.6 lbs)
My 2021 Turbo Levo Comp (700Wh battery), XL Frame, inc bottle cage, tool, Shimano M8120 pedals, tubeless tyres, Specialized Power Comp saddle is 23.5kg (51.8lbs). This was measured using a digital luggage weighing tool (which I believe is fairly accurate as we use it when we [used to] travel).
Anyone know what the weight of the 2021 Turbo Levo Expert is please? Google say 38 lbs, but not sure if that's accurate?
That's certainly incorrect. A Turbo Levo SL S-Works is about 38 lbs. Stock weight on a standard Turbo Levo Expert is 47-48lbs.
Al
2021 Levo Comp Alu - M - 51.32 pounds
2019 Levo Expert Cbn - S - 47.6 pounds
    Join 43,269
