Beekeeper
🍯Honey Monster🍯
Any suggestions on how to lubricate the derailleur other than where the chain goes. Should I use some kind of light oil spray to get into all the other parts of it? Also what about gear and brake levers?
i use it on my motorbike. It is a brilliant anti rust coating and guard against salt. But shit sticks to it like a blanket. Your supposed to let the crud stick all winter and wash off again in spring. Underneath it’s as good as new. Best winter protection you can get!You will not beat Acf50, especially on contact parts like allen bolt heads and bolt through axles.
Comes as grease, spray or lube.
I've noticed that too but considerd what doesnt attract dirt on bolt heads etc? with assembled parts just wipe off the excess and its no problem.i use it on my motorbike. It is a brilliant anti rust coating and guard against salt. But shit sticks to it like a blanket. Your supposed to let the crud stick all winter and wash off again in spring. Underneath it’s as good as new. Best winter protection you can get!
But @Jaygam would you recommend it as a lubricant though as the crud sticks to it like a magnet?
That’s what I use on the Jocky wheels. I also rub the frame and wheel hubs with it and a cloth I used it as a degreaser on my chain. But it thins the oil out you put on after so no good! I use it on cable ends, levers etc!I am a sucker for WD40 or similar. Nice spritzer tube so you can point it where you want it then wipe off with a clean soft cloth.
Yes and no.wd40 is a cleaner not a lubricant!
For SRAM brake levers, never ever put anything else than DOT grease. Any oil, specially if sprayed goes easily to master piston and easily damages the seals. Believe me, I have done itAlso what about gear and brake levers?
Honestly if you think wd40 is good, really do try acf50, I had a crappy pin style padlock on the garage that got wet and tarnished inside, it was a real pain in the butt... wd40 did nothing, acf50 made it perfectly useable again and not had to maintain it again since.WD-40® Multi-Use Product protects metal from rust and corrosion, penetrates stuck parts, displaces moisture and lubricates almost anything
