Bike finally arrived... not sure if a 625 Wah Bosch battery fits
Feb 5, 2019
163
28
Wales
Here is the inside of the battery compartment that holds the 500 Wah:
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,593
5,194
North Yorkshire
I had an AllMtn 4 this week. You have to make sure the plastic / rubber cover on the battery is fitted properly and slid all the way to the top of the battery otherwise its difficult to fit the battery in
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,593
5,194
North Yorkshire
Aah just read that you’ve got a 500Wh battery, didn’t see that earlier - which model bike is it ? Sometimes you can move the position of the battery connection but it depends on the model
Hamina
493
391
FIN
If your 500wh battery has plastic extension then it's possible to change to 625wh = The current lenght is the same as 625wh only.
Take a picture of your battery
Mteam
1,789
1,726
gone
Were you expecting a 625wh battery to fit?
Did you ask the shop before you bought it if a 625wh battery would fit?
Hamina
493
391
FIN
Your battery doesn't have the extension part so therefore it will be impossible to fit bigger battery without very heavily modifying the frame (read: it's not possbile.)
