Motors · Rocky Mountain
Rocky Mountain · Rocky Mountain Dyname (Powerplay SL lightweight)
Dyname S4 Lite
Rocky Mountain's lightweight take on its in-house Dyname drive: a magnesium-cased, chain-tension-sensing motor that trades all-out grunt for a trail-natural feel, and which a September 2025 firmware update bumped from 65 Nm to a claimed 75 Nm.
Dyname S4 Lite eMTB motor
The Dyname drive unit: the motor sits above the bottom bracket and drives the cranks via a separate sprocket, with a second sprocket reading chain tension to sense rider input.
0250500750406080100700 Wcadence (rpm) →power (W)
Builds steadily off the bottom and peaks high in the cadence range — emtb-test measured maximum output at 90 rpm at the crank — then tapers at very high rpm. Shape derived from the Dyname 4.0 bench test and scaled to the Lite's claimed peak; not measured for the Lite.
The verdict
Rocky Mountain Dyname S4 Lite is the brand's answer to the mid-power, lightweight class, and it does it on Rocky's own terms rather than buying in a TQ or Fazua. Like the full-fat Dyname 4.0, the actual motor sits above the bottom bracket and drives the cranks through a separate sprocket, with a second sprocket reading chain tension to sense rider input. A magnesium housing and slimmed internals keep it to a claimed 2.26 kg, and it pairs with a slender 480 Wh battery (plus an optional 314 Wh Overtimepack 2.0 range extender) to keep the whole package trail-bike trim.
At launch it was rated 65 Nm and 550 W peak, but a September 2025 dealer-installed firmware update lifted that to a claimed 75 Nm and 700 W, a ~27% jump that closes much of the gap to the heavier full-power class without adding weight. Those are Rocky's figures; on emtb-test's bench the Lite delivered around 490 W with a 150 W rider input, and the closely related full-power Dyname 4.0 measured 573 W peak on Velomotion's dyno, so the 700 W headline is a peak ceiling rather than a sustained, independently verified number. The defining trait is the tuning: it is very sporty and rewards an active rider. Pedal hard and it surges with genuinely natural, controllable assistance; soft-pedal and it gives little back, which makes it less of a chairlift and more of an amplifier.
That character won't suit everyone, but for riders who want the bike to feel like a bike, the S4 Lite is one of the more honest motors out there. emtb-test note it runs without overrun, cutting support the instant you stop pedalling, and that peak output arrives high up at 90 rpm at the crank, so it rewards spinning rather than mashing. It is not silent, though: emtb-test put it on a par with Bosch's SX for audible noise rather than the near-mute TQ. Independent dyno figures for the Lite specifically aren't published, so the power curve shown here is a representative shape derived from the Dyname 4.0 bench test scaled to the Lite's claimed peak, with the peak placed at the measured 90 rpm crank cadence.
“It's not a chairlift, it's an amplifier: pedal hard and the Dyname surges; soft-pedal and it gives little back.”
Character
Rider input
Rocky doesn't publish a single support ratio; the Powerplay system runs named modes — Eco, Trail, Trail+ and Ludicrous — with factory power levels that step up to full assist in Ludicrous, plus two fully customisable Tune A/Tune B power maps set on the Jumbotron display. The tuning is sporty and input-hungry: it pays out big when you pedal hard but gives little back if you soft-pedal, so it rewards an active rider over a passive one.
On the trail
Natural, controllable and immediate thanks to chain-tension input sensing, with no overrun — support cuts the moment you stop pedalling. It amplifies a strong pedalling rider rather than carrying a lazy one, which makes it feel more like a bike and less like a motorbike.
Noise
Runs at low rpm with a soft whine rather than a high-pitched buzz, but it is not silent: emtb-test rate it as audible on climbs, roughly on a par with Bosch's SX and louder than a TQ HPR50 — noticeably quieter, though, than a full-power Bosch CX.
Efficiency
No standalone efficiency test exists for the Lite. emtb-test's range run returned 1,375 m of climbing in Ludicrous mode from the 480 Wh pack, and the related Dyname 4.0 returned roughly 6.6 Wh/km on the flat and 28.2 Wh/km climbing on Velomotion's bench; the lighter Lite is tuned for trail range over outright power.
The case for and against
Strengths
  • Distinctive chain-tension sensing gives immediate, natural input response with no overrun
  • Light for its claimed output (magnesium housing, 2.26 kg)
  • Highest claimed torque and peak power in the lightweight class (75 Nm / 700 W)
  • Free 2025 firmware update lifts it from 65 Nm / 550 W to a claimed 75 Nm / 700 W
  • Sporty, controllable feel that rewards an active rider; strong real-world climbing (1,000 m in 29 min)
Compromises
  • Input-hungry tuning gives little back if you soft-pedal
  • Heaviest motor in the lightweight bracket on paper
  • Audible on climbs — emtb-test rate it on a par with Bosch SX, not whisper-quiet like a TQ
  • No independent dyno of the headline 700 W — bench-measured ~490 W at 150 W input
  • Firmware upgrade is dealer-only, not user-installable
How it stacks up
It plays in the same lightweight bracket as TQ's HPR50 (50 Nm / 300 W / 1.85 kg), the Fazua Ride 60 (60 Nm / 450 W / 1.96 kg), Bosch's SX (55 Nm / 600 W / 2.0 kg) and Specialized's SL 1.2 (50 Nm / 320 W / 1.95 kg). On paper its claimed 75 Nm and 700 W top that group for both torque and peak power, but at a claimed 2.26 kg it is also the heaviest of the five — so the headline-figure lead comes with a small weight penalty. Where TQ chases silence and Bosch SX chases punch, the Dyname leans into a sporty, input-driven feel closer to a Specialized SL in spirit. It still can't match a full-power Bosch CX or Rocky's own Dyname 4.0 for low-cadence shove, which is the price of the weight saving.
OWNER INTELLIGENCE
Most owners report no problems.
Bikes running this motor · 1
