Motors · Bosch
Bosch · Performance Line CX-R (Gen5 race variant, replaces CX Race BDU376Y)
Bosch Performance Line CX-R Gen 5
Bosch Performance Line CX-R, Gen 5 (Smart System era) — the Race-tuned variant, fitted to premium / top-tier builds. Current torque 120 Nm (Performance Update 2.0, May 2026); firmware history 85 -> 100 -> 120 Nm. State 120 as current; 85/100 are historical.
Torque
120 Nm
Rated power
250 W
Peak (claimed)
750 W
Peak (measured)
723 W
Weight
2.72 kg
Voltage
36.0 V
EMTB Forums verdict
Bosch Performance Line CX-R Gen 5 is the race-tuned flagship of Bosch's Smart System mid-drive family, sitting one rung above the standard CX-R Gen 5 and built for premium full-power enduro and trail builds. The headline numbers: 120 Nm nominal torque, 750 W claimed peak (723 W on independent dynos), 36 V architecture, and a 2.72 kg drive unit. It replaces the previous CX Race (BDU376Y) and arrived May 2025, with Performance Update 2.0 in May 2026 lifting torque from the original 85 Nm through 100 Nm to today's 120 Nm via firmware alone. As one forum member put it, the gen-5 platform is where Bosch finally stopped chasing rivals on paper and started leaning on control.
The numbers. Bosch claims 750 W peak; the best independent dyno run we have logged is 723 W, so the headline figure is honest within roughly 4 per cent. Torque is the more interesting story: launch firmware shipped 85 Nm, a May 2025 OTA bumped it to 100 Nm, and the PU2.0 release (firmware 19.24.0, May 2026) takes the CX-R variant to 120 Nm nominal. There is no separate boost figure quoted — 120 Nm is the sustained number, not a two-second peak. @jacob80 confirms the 85 to 120 Nm range now shipping on 2026 builds, and @AlsbachRyder notes the update installs through the Flow app under Components > Drive Unit > Performance Update 2.0. Rated continuous remains 250 W, as it must for EU EPAC compliance.
Character and feel. The CX-R's defining trait is Dynamic Control, which @Shark58 describes as traction control on loose or damp surfaces, driven by built-in sensors that read trail and rider input without external cabling. Post-PU2.0, @steve_sordy confirms the Dynamic slider now works across every mode from Eco to Turbo, not just Turbo and eMTB+ as some early notes suggested — that matters because it gives you a tunable aggression curve in Trail without forcing a mode change. The wider community framing, captured by @robikinkela, is that the gen-5 Bosch leans hard on control rather than raw shove. Drag off-power is low but not silent; you can feel the motor at 28 km/h plus, less than a Brose, more than an Avinox M2S.
Compatibility and ecosystem. The CX-R runs Bosch Smart System, so battery options are PowerTube 400, 600, 800 Wh internal, plus the PowerMore 250 Wh range extender for a theoretical 1050 Wh on an 800 Wh frame. Displays span Purion 200, Kiox 300/500 and the larger Nyon — @Ebikes-Unlimited notes the Nyon pairing on long-travel touring builds. The Mini Remote handles bar input. Firmware lives in the Flow app over Bluetooth, with OTA pushes like PU2.0 going straight to the drive unit. Standards are conventional: Boost 148 rear, ISIS spindle, and chainline tuned to 55 mm for modern enduro frames.
Reliability and known issues. The gen-5 BDU384Y platform has been broadly dependable through 2025-26, with no factory recall on the CX-R variant. The most-reported headache is third-party tuning: @TrekPwrfly documents a SpeedBox 1.1 triggering error 524001 (Speed Manipulation Detected) on firmware 12.13.0 after roughly 100 km, and the lockout is sticky. Long-term ownership reports like @deertrackdoctor's 2000 km check-in flag frame-side niggles (shock bolts, battery cradle rattle) rather than motor faults. community testers note the early 85 Nm units have aged gracefully into 120 Nm through firmware, with no reported drivetrain failures attributable to the torque uplift.
Bikes you'll find it on. We have no confirmed CX-R Gen 5 builds on file in the bike-finder database yet — the variant is recent enough that 2026 model-year listings are still being added. Community reports point to the motor appearing on top-tier Trek Rail+, Mondraker Crafty R, and Cube One77 SLX builds, typically the halo trim where the standard CX would otherwise sit. @ryanflynn11's One77 impression captures the typical reaction: confidence on technical climbs, composed on descents.
Verdict. The CX-R Gen 5 suits riders who want 120 Nm of metered, sensor-managed torque with a proper firmware roadmap and accept a 2.72 kg drive unit and 36 V architecture rather than the lighter, higher-voltage Avinox M2S route. The honest trade-off is weight: at 2.72 kg it is roughly 300 g heavier than the lightest full-power rival, and you feel that on lift-and-place moves. Current flagship, launched May 2025, PU2.0 firmware May 2026, no announced replacement.
Power profile
ConditionPeakTorqueType
fw: launch 2023— W85.0 NmSustained
fw: May 2025 OTA— W100.0 NmSustained
fw: PU2.0 May 2026 (CURRENT)— W120.0 NmSustained
