Bike Finder · YT
YT Decoy MX
YT
Decoy MX 2026
DiscontinuedEnduro eMTBLegacy · 2.9/10iFreshness 2.9/10
Travel F/R
170/165mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
23.7 kg
Price
From £4,999
View the YT Decoy MX on YT’s site
YT Decoy MX 2026
From £4,999
EMTB Forums verdict
The Decoy MX is YT's gravity-leaning mullet e-MTB, built around a carbon frame with 170mm up front and 165mm out back, a Shimano EP801 motor (85Nm, 600W peak) and a custom 720Wh battery on the Core 5 and Core 3. It runs a 29in front and 27.5in rear wheel and a flip chip that swings the head angle between 65 and 64.5 degrees, the seat angle between 76 and 75.5 degrees, and the BB height between 352mm and 344mm.
Across the three trims the value picture is clear. The Core 1 at £4,999 drops to the lower-output Shimano EP6 motor and a 540Wh battery with a RockShox Domain fork and SRAM DB8 brakes, so it is the heavier, less powerful entry point. The Core 3 at £5,999 steps up to the full EP801 and 720Wh pack with a Fox 38 Performance fork, DHX coil shock and Shimano SLX. The £7,999 Core 5 is the halo build: Fox Factory 38 and Float X2, Shimano XT Di2 with FREE SHIFT, SRAM Code RSC brakes and Crankbrothers Synthesis wheels on Industry Nine hubs.
Geometry sits on the conservative side for an enduro bike of this era. The four-size range runs medium to XXL, but the reach figures of 429 to 489mm are closer to what other brands label small to extra-large, so size up if you want length. Chainstays are a fixed 442mm across all sizes, and the seat angle is on the slacker side, which favours descending composure over steep, technical climbing. Note that the Shimano-powered Decoy MX has now been superseded by YT's Avinox M2S-powered Decoy X, so the MX is best viewed as a run-out or used buy.
OWNERS’ REPORT
YT Decoy family — what owners actually know
9,612 posts · 1,136 owners · data through Jun 2026
63The 700Wh battery that took three years · typical onset: n/a
29Battery warranty policy and battery faults (E8000 era) · typical onset: Policy: at purchase.
14Display freeze / water-related electrics (E8000 era) · typical onset: First washes; wet winters.
No Decoy frame-crack cluster in 9,612 posts across seven years; the crack net resolved to other bikes and general carbon debates.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
MLXLXXL
Reach429 mm449 mm469 mm489 mm
Stack629 mm633 mm643 mm652 mm
Seattube420 mm445 mm470 mm495 mm
Chainstay442 mm442 mm442 mm442 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1213 mm1235 mm1259 mm1284 mm
Headtube100 mm105 mm115 mm125 mm
BB Height344 mm344 mm344 mm344 mm
Standover738 mm724 mm714 mm702 mm
Front Centre771 mm*793 mm*817 mm*842 mm*
Trims · 3
Core 1
£4,999
Core 3
£5,999
Core 5
£7,999
MotorShimano EP6 (DU-EP600) · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 Nm
BatteryYT 720Wh · 720 Wh · all trims
Travel F/R170/165 mm · all trims
FrameCarbonCarbonCarbon (Ultra Modulus)
ForkRockShox Domain, 170mm (38mm stanchions)Fox 38 Performance, 170mmFox 38 Float Factory E-Bike+, 170mm
ShockRockShox Deluxe CoilFox DHX Performance coilFox Float X2 Factory
HeadsetAcros AZX-260 · all trims
Steme*thirteenRenthal ApexRenthal Apex 35, 50mm
Handlebare*thirteenRenthal FatbarRenthal Fatbar 35, 800mm
GripsODI Elite MotionODI Elite MotionODI Elite Motion V2.1
SaddleSDG Bel Air V3SDG Bel Air V3SDG Bel Air V3 Max
SeatpostYT Postman V2 dropper · all trims
BrakesSRAM DB8SRAM Code RSRAM Code RSC
Rear derailleurShimano Deore 12-speedShimano SLX 12-speedShimano XT RD-M8150 Di2 (1x12)
CrankShimano e-MTB crankShimano EM900Shimano XT FC-EM900, 36T
ShiftersShimano DeoreShimano SLXShimano XT SL-M8150-R Di2
CassetteShimano Deore 10-51TShimano SLX/Deore 10-51TShimano XT CS-M8100, 10-51T
ChainShimano Deore 12-speedShimano 12-speedShimano CRE80-12
DrivetrainShimano Deore 12-speed; Shimano e-MTB crank; Shimano Deore; Shimano Deore 10-51T; Shimano Deore 12-speedShimano SLX 12-speed; Shimano EM900; Shimano SLX; Shimano SLX/Deore 10-51T; Shimano 12-speedShimano XT RD-M8150 Di2 (1x12); Shimano XT FC-EM900, 36T; Shimano XT SL-M8150-R Di2; Shimano XT CS-M8100, 10-51T; Shimano CRE80-12
WheelsSun Ringle DurocCrankbrothers Synthesis Alloy E-MTBCrankbrothers Synthesis Alloy E-MTB with Industry Nine 1/1 hubs
TyresFront: Maxxis Assegai Double Down / Rear: Maxxis Minion DHR II Double DownFront: Maxxis Assegai Double Down / Rear: Maxxis Minion DHR II Double DownFront: Maxxis Assegai 29x2.5in 3C MaxxGrip Double Down / Rear: Maxxis Minion DHR II 27.5x2.4in 3C MaxxTerra Double Down
Weight24.7 kg25.2 kg23.7 kg
Price£4,999£5,999£7,999
Rides similarly
Spot a mistake?
