Bike Finder · Whyte
Whyte E-505
Whyte
E-505 2023
DiscontinuedHardtail eMTBLegacy · 1/10iFreshness 1/10
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£3,499
View the Whyte E-505 on Whyte’s site
Whyte E-505 2023
From £3,499
EMTB Forums verdict
The E-505 was Whyte's 29er electric hardtail, pitched as a do-it-all machine for trail riding and commuting alike, with the brand itself calling it the Land Rover Defender of e-bikes. At £3,499 it paired a full-power Bosch Performance Line CX motor (85Nm, Purion display) and a removable 500Wh PowerTube battery with a 6061 T6 aluminium frame, a sensible spec for the money in 2023.
The single build was honest rather than flashy: a 120mm RockShox 35 Silver TK fork, SRAM GX 1x11 shifting with an 11-42 cassette, Tektro Orion four-piston brakes on 200mm rotors at both ends, tubeless-ready WTB ST i30 rims and high-volume 29x2.6in Maxxis Forekaster tyres. A 150mm Whyte drop.it dropper post came as standard, which was not a given on hardtail e-bikes at this price.
Geometry was confident for an e-hardtail: a 65.5 degree head angle across the M, L and XL sizes, 447 to 479mm reach, 450mm chainstays and a low 305mm bottom bracket. Riders needing smaller sizes were pointed at the 27.5in-wheeled E-504 sibling.
The E-505 is discontinued. It carried over from the 2022 range through 2023, and while the product page still lingers on Whyte's site marked sold out online, the bike has long since left the catalogue with no direct hardtail replacement; Whyte's eMTB range subsequently centred on the full-suspension E-160, E-180 and lightweight ELyte platforms.
Bike geometry diagram
MLXL
Reach447 mm463 mm479 mm
Stack645 mm655 mm664 mm
Seattube444.5 mm495.7 mm533.4 mm
Chainstay450 mm450 mm450 mm
Headtube Angle65.5°65.5°65.5°
Seattube Angle (eff)74.5°74.5°74.5°
Wheelbase1198 mm1217 mm1237 mm
Headtube115 mm125 mm135 mm
BB Height305 mm305 mm305 mm
Standover825 mm844 mm851 mm
Front Centre748 mm*767 mm*787 mm*
Trims · 1
Base
£3,499
MotorBosch Performance Line CX Gen 4 · 85 Nm
BatteryBosch PowerTube 500 · 500 Wh
Travel F/R120/? mm
Frame6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal Cable Routing for Dropper Post and 12mm X 148mm Boost Dropouts
ForkRockShox 35 Silver TK 29", 120mm Travel, 44mm Offset, DebonAir, Fast Black Coating, Adjustable Compression and Rebound, Tapered Steerer, 110mm x 15mm Boost, Maxle Lite
ShockN/A (hardtail)
HeadsetFSA No. 57B Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Caged Bearings
StemWhyte Alloy 6061, 35mm Extension
HandlebarWhyte 6061 Alloy, 30mm Rise, 31.8mm, 780mm Wide
GripsWhyte Lock-on V Grip
SaddleWhyte Custom, Triple Panel Design
SeatpostWhyte drop.it, 30.9, 150mm Travel, Paddle Remote Lever
BrakesTektro Orion, 4-Piston with Sintered Metal Pads, 200mm Disc front and rear, Post Mount
Rear derailleurSRAM GX, 11 Speed
CrankWhyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black
ShiftersSRAM GX, 11 Speed
CassetteSRAM PG-1130, 11-42, 11 Speed
ChainKMC NPBK Sport, 11 Speed
DrivetrainSRAM GX, 11 Speed; Whyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black; SRAM GX, 11 Speed; SRAM PG-1130, 11-42, 11 Speed; KMC NPBK Sport, 11 Speed
WheelsWTB ST i30 TCS 2.0 System, Pinned Joint, Tubeless Ready, 32 Hole
TyresMaxxis Forekaster TR 29" x 2.6" 60TPI, EXO Sidewall Protection
Price£3,499
Rides similarly
Spot a mistake?
