E-505 2022
The E-505 was the middle bike in Whyte's three-strong aluminium e-hardtail range, sitting between the compact E-504 and the SUV-style E-506. It paired a full-power Bosch Performance Line CX motor (85Nm) and an integrated but removable PowerTube 500Wh battery with 29in wheels, a 120mm RockShox 35 Gold RL fork and a Purion display, at a launch-era price of 3,825 pounds in a single build.
For a hardtail the kit was unusually trail-ready: four-piston Tektro Orion brakes on 200mm rotors front and rear, 2.6in Maxxis Forekaster tyres on 30mm WTB rims, a 150mm Whyte drop.it dropper and a 780mm bar. The 11-speed SRAM GX drivetrain with an 11-42 cassette was the clearest concession to the price point, and Whyte never published a claimed weight.
The geometry backed up Whyte's 'Enduro influenced' billing for the class: a 65.5 degree head angle, generous 447 to 479mm reach across M, L and XL, long 450mm chainstays and a low 305mm bottom bracket made it a stable, planted hardtail rather than a nervous commuter crossover.
The E-505 is long discontinued. It carried on into 2023 with a downgraded RockShox 35 Silver TK fork at 3,499 pounds before the e-hardtail line was dropped entirely; Whyte's current eMTB range is all full suspension, with no direct hardtail successor.
| M | L | XL | |
| Reach | 447 mm | 463 mm | 479 mm |
| Stack | 645 mm | 655 mm | 664 mm |
| Seattube | 444.5 mm | 495.7 mm | 533.4 mm |
| Chainstay | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 74.5° | 74.5° | 74.5° |
| Wheelbase | 1198 mm | 1217 mm | 1237 mm |
| Headtube | 115 mm | 125 mm | 135 mm |
| BB Height | 305 mm | 305 mm | 305 mm |
| Standover | 825 mm | 844 mm | 851 mm |
| Front Centre | 748 mm* | 767 mm* | 787 mm* |
Trims · 1
Base £3,825 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm |
| Battery | Bosch PowerTube 500 · 500 Wh |
| Travel F/R | 120/? mm |
| Frame | 6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal Cable Routing for Dropper Post and 12mm X 148mm Boost Dropouts |
| Fork | RockShox 35 Gold RL 29", 120mm Travel, 44mm Offset, DebonAir, Fast Black Coating, Adjustable Compression and Rebound, Tapered Steerer, 110mm x 15mm Boost, Maxle Lite |
| Headset | FSA No. 57B Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Caged Bearings |
| Stem | Whyte Alloy 6061, 35mm Extension |
| Handlebar | Whyte 6061 Alloy, 30mm Rise, 31.8mm, 780mm Wide |
| Grips | Whyte Lock-on V Grip |
| Saddle | Whyte Custom, Triple Panel Design |
| Seatpost | Whyte drop.it, 30.9, 150mm Travel, Paddle Remote Lever |
| Brakes | Tektro Orion, 4-Piston with Sintered Metal Pads, 200mm Disc, Post Mount (front and rear), Tektro Orion levers |
| Rear derailleur | SRAM GX, 11 Speed |
| Crank | Whyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black |
| Shifters | SRAM GX, 11 Speed |
| Cassette | SRAM PG-1130, 11-42, 11 Speed |
| Chain | KMC NPBK Sport, 11 Speed |
| Drivetrain | SRAM GX, 11 Speed; Whyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black; SRAM GX, 11 Speed; SRAM PG-1130, 11-42, 11 Speed; KMC NPBK Sport, 11 Speed |
| Wheels | WTB ST i30 TCS 2.0 System, Pinned Joint, Tubeless Ready, 32 Hole |
| Tyres | Maxxis Forekaster TR 29" x 2.6" 60TPI, EXO Sidewall Protection |
| Price | £3,825 |
Rides similarly
Spot a mistake?
