E-504 2023
The E-504 was the compact entry in Whyte's electric hardtail line, built specifically for smaller riders. It paired a 6061 T6 aluminium frame with 27.5in wheels and XS, S and M sizes only, while the otherwise identical E-505 covered the bigger 29in sizes. Power came from a Bosch Performance Line CX motor with an 85Nm rating and a removable 500Wh PowerTube battery, controlled through a Purion display.
At £3,499 the single build was sensibly specced rather than flashy: a 120mm RockShox 35 Silver TK fork, SRAM GX 11-speed shifting with an 11-42 cassette, Tektro Orion four-piston brakes on 200mm rotors, tubeless-ready WTB i30 rims with 2.6in Maxxis Forekaster tyres, and a Whyte drop.it dropper post fitted as standard on every size.
The geometry was unusually progressive for a hardtail of its day, with a 64 to 64.5 degree head angle, 440mm chainstays and a 305mm bottom bracket height, giving reach figures of 403 to 450mm across the three sizes. That slack front end and the high-volume tyres were aimed at giving genuine off-road confidence rather than just bridleway pottering.
The E-504 is discontinued and has no direct successor; Whyte's current e-bike range has moved entirely to full-suspension models such as the ELyte, E-160 and Karve, leaving the E-50x hardtail series as a closed chapter in the brand's catalogue.
| XS | S | M | |
| Reach | 403 mm | 421 mm | 450 mm |
| Stack | 600 mm | 610 mm | 610 mm |
| Seattube | 381 mm | 406 mm | 444 mm |
| Chainstay | 440 mm | 440 mm | 440 mm |
| Headtube Angle | 64° | 64.5° | 64.5° |
| Seattube Angle (eff) | 74.5° | 74.5° | 74.5° |
| Wheelbase | 1146 mm | 1163 mm | 1193 mm |
| Headtube | 107 mm | 115 mm | 115 mm |
| BB Height | 305 mm | 305 mm | 305 mm |
| Standover | 712 mm | 728 mm | 758 mm |
| Front Centre | 706 mm* | 723 mm* | 753 mm* |
Trims · 1
Base £3,499 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm |
| Battery | Bosch PowerTube 500 · 500 Wh |
| Travel F/R | 120/? mm |
| Frame | 6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal Cable Routing for Dropper Post and 12mm x 148mm Boost Dropouts |
| Fork | RockShox 35 Silver TK 27.5", 120mm Travel, 37mm Offset, DebonAir, Fast Black Coating, Adjustable Compression and Rebound, Tapered Steerer, 110mm x 15mm Boost, Maxle Lite |
| Headset | FSA No. 57B Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Caged Bearings |
| Stem | Whyte Alloy 6061, 35mm Extension |
| Handlebar | Whyte 6061 Alloy, XS and S 15mm Rise, 31.8mm, 760mm; M 30mm Rise, 31.8mm, 780mm Wide |
| Grips | Whyte Lock-on V Grip |
| Saddle | Whyte Custom, Triple Panel Design |
| Seatpost | Whyte drop.it, 30.9, XS 100mm, S 125mm, M 150mm Travel, Paddle Remote Lever |
| Brakes | Tektro Orion, 4-Piston with Sintered Metal Pads, 200mm Disc, Post Mount (front and rear) |
| Rear derailleur | SRAM GX, 11 Speed |
| Crank | Whyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black |
| Shifters | SRAM GX, 11 Speed |
| Cassette | SRAM PG-1130, 11-42, 11 Speed |
| Chain | KMC NPBK Sport, 11 Speed |
| Drivetrain | SRAM GX, 11 Speed; Whyte, Steel narrow/wide, 165mm, Direct Mount 36T for Bosch Performance Line CX, Black; SRAM GX, 11 Speed; SRAM PG-1130, 11-42, 11 Speed; KMC NPBK Sport, 11 Speed |
| Wheels | WTB ST i30 TCS 2.0 System, Pinned Joint, Tubeless Ready, 32 Hole (DT Swiss Champion 2.0mm spokes, alloy e-bike specific hubs) |
| Tyres | Maxxis Forekaster TR 27.5" x 2.6" 60TPI, EXO Sidewall Protection |
| Price | £3,499 |
Rides similarly
Spot a mistake?
