Bike Finder · Whyte
Whyte E-160
Whyte
E-160 2025
DiscontinuedTrail/Enduro eMTBLegacy · 2.8/10iFreshness 2.8/10
Travel F/R
160/155mm
Wheels
29F / 29R
Frame
Aluminium
Weight
26.3 kg
Price
From £5,499
View the Whyte E-160 on Whyte’s site
Whyte E-160 2025
From £5,499
EMTB Forums verdict
The E-160 is Whyte's full power alloy trail and enduro platform: 160mm Fox or RockShox fork, 155mm rear travel, a Bosch Performance Line CX Gen 4 motor and a big 750Wh in-tube battery in a multi-butted 6061 T6 aluminium frame. Whyte pitches it as a trail/enduro all-rounder, and every E-160 with the fourth generation BDU37 motor gets the free Bosch software update that unlocks E-MTB+ mode from July 2025.
The £6,399 RS is the value pick of the range: SRAM GX T-Type AXS wireless shifting, a Fox 38 Performance fork with custom-tuned Float DPS shock, Code R four-piston brakes on 220/200mm rotors and Double Down rear tyre casing. The £6,999 RSX adds Performance Elite Fox suspension with a Grip 2 damper and Float X shock, DT Swiss 350 hubs on HX 1700 rims and Code RSC brakes for £600 more, though it only comes in M to XL. The £5,499 S keeps the wireless GX AXS drivetrain but moves to a RockShox ZEB and Deluxe Select R with Guide RE brakes, making it one of the cheaper routes to a 750Wh Bosch full-suspension bike.
Geometry follows Whyte's Total Geometry approach: a 64.8 degree head angle, 455mm reach on a Medium and long 444 to 446mm rear centres, with XS and S sizes on 27.5in wheels and M to XL on 29ers. The Shape.It Link flip chip slackens the head angle by 0.6 degrees and drops the bottom bracket 8mm from the stock High setting. At 26.3 to 27kg claimed these are not light bikes, but the low-slung battery and motor placement is central to Whyte's handling pitch.
💬 Forum discussion
Whyte e160S or Specialized turbo Levo
41 replies · 12.5k views · last reply 68 months ago
Join the discussion →
Bike geometry diagram
XSSMLXL
Reach405 mm425 mm455 mm483 mm510 mm
Stack607.8 mm619.7 mm631.5 mm645.1 mm658.6 mm
Seattube360 mm395 mm420 mm445 mm470 mm
Chainstay444 mm444 mm446 mm446 mm446 mm
Headtube Angle64.8°64.8°64.8°64.8°64.8°
Seattube Angle (eff)76.1°75.7°75.5°75.3°75.1°
Wheelbase1181.2 mm1200.4 mm1234.8 mm1269.2 mm1302.7 mm
Headtube120 mm130 mm105 mm120 mm135 mm
BB Height347 mm347 mm340 mm340 mm340 mm
Standover768 mm769 mm771 mm773 mm776 mm
Front Centre737.2 mm*756.4 mm*788.8 mm*823.2 mm*856.7 mm*
Trims · 3
S
£5,499
RS
£6,399
RSX
£6,999
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R160/155 mm · all trims
Frame6061 alloy, hydroformed T6 aluminium, multi-butted, custom drawn, tapered headtube, internal cable routing, Shape.it Link, 12x148mm Boost dropouts · all trims
ForkRockShox ZEB, 160mm travel, 44mm offset, DebonAir, Rush RC damper, Fast Black coating, tapered steerer, 110mm x 15mm Boost, Maxle UltimateFox Float 38 Performance, 160mm travel, 44mm offset with Grip damper, three-position adjustable, tapered steerer, 110mm x 15mm Boost, E-thru-axleFox Float 38 Performance Elite 29in, 160mm travel, 44mm offset with Grip 2 damper, tapered steerer, 110mm x 15mm Boost, E-thru-axle
ShockRockShox Deluxe Select R, Fast Black coating, adjustable reboundFox Float Performance DPS, EVOL LV, custom tuned for Whyte, three position adjustable compression and rebound dampingFox Float X Performance Elite DPS, EVOL LV, custom tuned for Whyte
HeadsetFSA No. 55R/35 Orbit 1.5 ZS, 1.8in lower and 1 1/8in upper sealed cartridge bearingsFSA No. 55/35 Orbit 1.5 ZS, 1.8in lower and 1 1/8in upper sealed cartridge bearingsFSA No. 55/35 Orbit 1.5 ZS, 1.8in lower and 1 1/8in upper sealed cartridge bearings
StemWhyte Enduro stem, 35mm bar bore, 35mm extensionWhyte Enduro, 35mm extension, 35mm bar boreWhyte Enduro, 35mm extension, 35mm bar bore
HandlebarWhyte Custom 6061 alloy, 30mm rise, 35mm bar bore, 780mm wideWhyte Custom 6061 alloy, 30mm rise, 35mm bar bore, 780mm wideWhyte Custom 6061 alloy, 30mm rise, 35mm bar bore, 800mm wide
GripsWhyte lock-on Enduro gripWhyte Enduro lock-onWhyte Enduro lock-on
SaddleWhyte Custom, dual density, triple panel designFizik Terra Aidon, 145mm wide, Wingflex, S-Alloy Mobius railFizik Terra Aidon, 145mm wide, Wingflex, S-Alloy Mobius rail
SeatpostWhyte drop.it Adjust, 30.9mm, M/L 140-170mm travel, XL 170-200mm travel, MMX paddle remote leverCrank Brothers HighLine 3, 30.9mm (sizes XS/S/M/L 150mm travel; size XL 170mm travel), Highline ball socket remote leverCrank Brothers HighLine 3, 30.9mm (sizes M/L 150mm travel; size XL 170mm travel), Highline ball socket remote lever
BrakesSRAM Guide RE, 4 piston with sintered metal pads, 220mm front / 200mm rear discs; SRAM Guide RE MMX leversSRAM Code R, four piston hydraulic with sintered metal pads, 220mm front / 200mm rear rotors; SRAM Code R MMX leversSRAM Code RSC, four piston hydraulic with sintered metal pads, 220mm front / 200mm rear rotors; SRAM Code RSC MMX levers
Rear derailleurSRAM GX AXS Eagle, 12 speedSRAM GX T-Type AXS, 12 speedSRAM GX T-Type AXS, 12 speed
CrankWhyte, forged alloy, 165mm, direct mount 36TWhyte, forged alloy, 155mm, direct mount 36T chainringRace Face A-Effect, 165mm, ISIS with X-SYNC 2, Direct Mount 36T chainring for Bosch Performance Line CX, black
ShiftersSRAM GX AXS Eagle, 2 button, MMX, 12 speedSRAM AXS Pod, two button MMX, 12 speedSRAM AXS Pod, two button MMX, 12 speed
CassetteSRAM PG1210, 11-50, 12 speedSRAM XS-1275 Eagle, 10-52T, 12 speedSRAM XS-1275 Eagle, 10-52T, 12 speed
ChainSRAM GX Eagle, 12 speedSRAM GX T-Type Eagle, 12 speedSRAM GX T-Type Eagle, 12 speed
DrivetrainSRAM GX AXS Eagle, 12 speed; Whyte, forged alloy, 165mm, direct mount 36T; SRAM GX AXS Eagle, 2 button, MMX, 12 speed; SRAM PG1210, 11-50, 12 speed; SRAM GX Eagle, 12 speedSRAM GX T-Type AXS, 12 speed; Whyte, forged alloy, 155mm, direct mount 36T chainring; SRAM AXS Pod, two button MMX, 12 speed; SRAM XS-1275 Eagle, 10-52T, 12 speed; SRAM GX T-Type Eagle, 12 speedSRAM GX T-Type AXS, 12 speed; Race Face A-Effect, 165mm, ISIS with X-SYNC 2, Direct Mount 36T chainring for Bosch Performance Line CX, black; SRAM AXS Pod, two button MMX, 12 speed; SRAM XS-1275 Eagle, 10-52T, 12 speed; SRAM GX T-Type Eagle, 12 speed
WheelsWTB HTZ i30 TCS 2.0 System, asymmetric, sleeved joint, super tough construction, tubeless ready, 32 hole; DT Swiss New Champion 2.0mm spokesWTB HTZ i30 TCS 2.0 System, asymmetric, sleeved joint, super tough construction, tubeless ready, 32 hole; DT Swiss New Champion 2.0mm spokesDT HX 1700 alloy, hooked 30mm internal width; DT Swiss 350 hubs, DT Swiss Hybrid straight pull spokes
TyresMaxxis Assigai WT, TR, 2.5in 120TPI, EXO+ casing, 3C Maxx Grip, Dual Compound, front; Maxxis Minion DHR II WT, TR, 2.4in 120TPI, Double Down, 3C Maxx Terra, Dual Compound, folding bead, rearMaxxis Assigai WT, TR, 2.5in 120TPI, EXO+ casing, 3C Maxx Grip, Dual Compound, front; Maxxis Minion DHR II WT, TR, 2.4in 120TPI, Double Down, 3C Maxx Terra, Dual Compound, folding bead, rearMaxxis Assigai WT, TR, 29in x 2.5in 120TPI, EXO+ casing, 3C Maxx Grip, Dual Compound, front; Maxxis Minion DHR II WT, TR, 29in x 2.4in 120TPI, Double Down, 3C Maxx Terra, Dual Compound, folding bead, rear
Weight27 kg26.7 kg26.3 kg
Price£5,499£6,399£6,999
Rides similarly
Spot a mistake?
