Fuel+ LX 2026
Long-travel trail Fuel+ with TQ HPR60 mid-power motor
The Trek Fuel+ LX 2026 is the long-travel 29er configuration in Trek's Gen 2 Fuel+ platform family. Built around the TQ HPR60 motor (60 Nm, 250 W rated, 350 W peak, 1.924 kg) and a 580 Wh battery, the LX runs 140 mm front and rear travel in the gold base spec, with longer-travel rocker and lower-shock-mount options pushing to 170/160 mm per @Twisted Fork. Head angle is a notably slack 63.4-63.5°, reach progresses across five sizes (S-XXL) from 418 mm to 518 mm, and chainstays scale with size from 444 mm to 452 mm. UK pricing spans £7,800-£10,475 across four trims, with a €12,000 base spec at the very top. The community verdict is overwhelmingly positive — @Free54 has covered "1,000 km" already and reports "the bike is really quiet and stable; 1,500 m elevation gain is no problem."
Drive system and range. The TQ HPR60 is the updated version of the HPR50, sharing the same coaxial harmonic-pin-ring design but with torque bumped from 50 Nm to 60 Nm and peak power lifted to 350 W. @coregrind notes: "The increase in power with the HPR60 over the HPR50 is a nice gain". The motor remains the quietest in eMTB and delivers famously natural pedal feel. The 580 Wh battery is generously sized for a TQ-powered platform (smaller 360 Wh and 160 Wh range extender options are also available, per @Twisted Fork). Expect 1,200-1,700 m of climbing per charge. @dotcodotuk reports the Fuel+ LX 9.9 weighs "approximately 17.5 kg without battery" with easy battery removal — viable for battery-free riding when desired.
Geometry and handling. The 63.4-63.5° head angle is properly slack for a 140 mm-travel platform and signals Trek's intent: this is a confident, capable trail bike that punches above its travel category. Reach progresses S 418 mm, M 448 mm, L 473 mm, XL 498 mm, XXL 518 mm — five sizes is excellent for fit. Size-specific chainstays grow from 444 mm on S-L to 452 mm on XXL. Wheelbase opens 1,213-1,341 mm. The Fuel+ LX accepts mullet 29/27.5 or full-29 configurations and angle-adjust headsets, plus @Twisted Fork documents "adjustable shock progression ratios from 18.0% to 24.7% and HTA of 63.4-65.0 depending on rocker link and lower shock mount choice" — an extremely versatile chassis.
Build and value. Four mainstream trims and a base spec span £7,800 to ~€12,000. The 9.8 XT and 9.8 Eagle 90 at £7,800 are the value plays. The 9.8 XT Di2 at £9,150 adds Shimano electronic shifting. The 9.9 X0 AXS at £10,475 is the SRAM AXS Transmission version. @Victorius spotted the 9.8 XT Di2 at €10,199 in continental Europe with Fox coil and Fox 38 Factory suspension — an aggressive spec for a lightweight trail bike. The €12,000 base trim is the headline-spec configuration.
Community-verified strengths. @Free54 has 1,000 km on his LX without complaint, noting "the bike is really quiet and stable; 1,500 m elevation gain is no problem". @nickf articulates the broader case for SL/lightweight bikes elegantly: the Fuel+ "gives 'enough' support without destroying the natural sensation of pedalling with human leg effort". The platform's configurability across EX (150/145 mm 29er), MX (160/150 mm mullet) and LX (170/160 mm 29er) configurations from one frame is genuinely class-leading.
Caveats and known gripes. @Yobbo reports a recurring issue: "After 550 miles (880 km), the same loud drivetrain creak that the EXE has a reputation for" — the TQ motor family has a known creak that needs diagnosing through chainring, BB, and pedal interfaces. The TQ HPR60's 60 Nm is mid-pack against Bosch CX Gen 5 (120 Nm) and Specialized 3.1 (105 Nm) — riders chasing maximum punch should look elsewhere. The £7,800 entry trim is still serious money. TQ motor service network outside Germany and the US is thin. The 580 Wh battery is small compared to Bosch/DJI 800 Wh equivalents.
Verdict. The Fuel+ LX is for the rider who wants Trek's flexible single-frame, five-size, three-configuration lightweight platform with the quietest motor in eMTB, slack 63.4° head angle and 17.5 kg unloaded weight. It is not for buyers chasing maximum torque, anyone needing a deep TQ service network, or budget-focused riders. Production status is current and the Fuel+ Gen 2 is Trek's headline 2026 lightweight platform.
| S | M | L | XL | XXL | |
| Reach | 418 mm | 448 mm | 473 mm | 498 mm | 518 mm |
| Stack | 633 mm | 633 mm | 647 mm | 661 mm | 674 mm |
| Chainstay | 444 mm | 444 mm | 444 mm | 447 mm | 452 mm |
| Headtube Angle | 63.4° | 63.4° | 63.4° | 63.5° | 63.5° |
| Seattube Angle (eff) | 77° | 76.7° | 76.3° | 75.9° | 75.4° |
| BB Drop | 26 mm | 27 mm | 27 mm | 27 mm | 27 mm |
| Wheelbase | 1213 mm | 1243 mm | 1275 mm | 1310 mm | 1341 mm |
| Headtube | 110 mm | 110 mm | 125 mm | 140 mm | 155 mm |
| Front Centre | 769 mm | 799 mm | 831 mm | 863 mm | 889 mm |
Trims · 5
9.8 Eagle 90 £7,800 | 9.8 XT £7,800 | 9.8 XT Di2 £9,150 | 9.9 X0 AXS £10,475 | 9.8 XT Gen 2 | |
| Motor | TQ HPR60 · 60 Nm · all trims | ||||
| Battery | 580 Wh · all trims | ||||
| Travel F/R | 170/160 mm · all trims | ||||
| Frame | Carbon · all trims | ||||
| Fork | Fox Factory 38, Float EVOL air spring, GRIP X2 damper, 44mm offset, 170mm travel | — | Fox Factory 38, Float EVOL air spring, GRIP X2 damper, 44mm offset, 170mm travel | Fox Factory 38, Float EVOL air spring, GRIP X2 damper, 44mm offset, 170mm travel | — |
| Shock | Fox DHX2, 205mm x 65mm, coil | — | Fox DHX2, 205mm x 65mm, coil | Fox DHX2, 205mm x 65mm, coil | — |
| Headset | ZS (zero stack) integrated headset | — | — | ZS (zero stack) integrated headset | — |
| Stem | Bontrager Elite, 35mm, 0 degree, 45mm length | — | Bontrager Elite, 35mm, 0 degree, 45mm length | Race Face Turbine R, 35mm, 0 degree, 40mm length | — |
| Handlebar | Race Face ERA, carbon, 35mm, 40mm rise, 800mm width | — | Race Face ERA, carbon, 35mm, 40mm rise, 800mm width | Race Face ERA, carbon, 35mm, 40mm rise, 800mm width | — |
| Grips | Trek Line Elite, lock-on | — | Trek Line Elite, lock-on | Trek Line Elite, lock-on | — |
| Saddle | Verse Short Comp, steel rails, 145mm width | — | Verse Short Comp, steel rails, 145mm width | Verse Short Pro, carbon rails, 145mm width | — |
| Seatpost | Bontrager Line Dropper, MaxFlow, 34.9mm, 150mm (S) / 170mm (M) / 200mm (L-XXL) travel | — | Bontrager Line Dropper, MaxFlow, 34.9mm, 150mm (S) / 170mm (M) / 200mm (L-XXL) travel | Fox Transfer NEO, Factory Series, wireless, 34.9mm, 150mm (S) / 175mm (M) / 200mm (L-XXL) travel | — |
| Brakes | SRAM Maven Bronze 4-piston hydraulic disc | — | Shimano XT M8220 4-piston hydraulic disc | SRAM Maven Silver 4-piston hydraulic disc | — |
| Rear derailleur | SRAM Eagle 90, T-Type | — | Shimano XT Di2 M8260, 12 speed | SRAM X0 Eagle AXS, T-Type | — |
| Crank | SRAM T-Type, 32T, alloy | — | E*Thirteen Helix Core Steel, 32t, 55mm chainline | SRAM X0 Eagle, 160mm length | — |
| Shifters | SRAM Eagle 90, 12 speed | — | Shimano XT Di2 M8250, 12 speed | SRAM AXS pod | — |
| Cassette | SRAM Eagle XS-1275, T-Type, 10-52, 12 speed | — | Shimano XT M8200, 10-51, 12 speed | SRAM Eagle XS-1295, T-Type, 10-52, 12 speed | — |
| Chain | SRAM GX Eagle, T-Type, 12 speed | — | Shimano Ultegra/XT M8100 | SRAM X0 Eagle, T-Type, 12 speed | — |
| Drivetrain | SRAM Eagle 90 T-Type | Shimano XT | Shimano XT Di2 | SRAM X0 AXS T-Type | — |
| Wheels | Bontrager Line Comp 30 alloy wheelset, Rapid Drive 108 rear hub, SRAM XD freehub, Boost110 front / Boost148 rear, 29'' | — | Bontrager Line Comp 30 alloy wheelset, Rapid Drive 108 rear hub, Shimano Micro Spline freehub, Boost110 front / Boost148 rear, 29'' | Bontrager Line Pro 30 OCLV Mountain Carbon wheelset, Rapid Drive 108 rear hub, Boost110 front / Boost148 rear, 29'' | — |
| Tyres | Maxxis Assegai 29x2.5 3C EXO+ MAXXGRIP front / Maxxis Minion DHR II 29x2.5 3C EXO+ MAXXTERRA rear | — | Maxxis Assegai 29x2.5 3C EXO+ MAXXGRIP front / Maxxis Minion DHR II 29x2.5 3C EXO+ MAXXTERRA rear | Maxxis Assegai 29x2.5 3C EXO+ MAXXGRIP front / Maxxis Minion DHR II 29x2.5 3C EXO+ MAXXTERRA rear | — |
| Weight | — | — | — | — | 20.9 kg |
| Price | £7,800 | £7,800 | £9,150 | £10,475 | — |
Rides similarly
Spot a mistake?
