Bike Finder · Transition
Transition Repeater PT
Transition
Repeater PT 2025
DiscontinuedFull Power · GravityAgeing · 3.2/10iFreshness 3.2/10
Playful full-power enduro with SRAM power and a steep price
Motor
SRAM Eagle Powertrain · 90Nm · 680W
Battery
SRAM Eagle Powertrain 720Wh
Travel F/R
170/170mm
Wheels
MX or 29F / 29R
Frame
Full carbon
Weight
23.95 kg
Price
From £10,499
View the Transition Repeater PT on Transition’s site
Set up this bike →
Transition Repeater PT 2025
From £10,499
EMTB Forums verdict
The Transition Repeater PT 2025 was Transition's full-power enduro eMTB built around the SRAM Eagle Powertrain motor (90 Nm torque, 250 W rated, 680 W manufacturer-claimed peak, 2.98 kg) and a 720 Wh Full-Size battery. Travel is properly aggressive at 170 mm front and 170 mm rear on a carbon Horst Link chassis. Three trims — GX AXS and (base) at £10,499 (24.0 kg), and X0 AXS at £11,999 (23.9 kg). Fifteen size/configuration combinations from SM to XL, reach 425-510 mm, head angle 63.5-64.0 degrees (size and flip-chip dependent), size-tuned chainstays 446-455 mm, wheelbase 1221-1326 mm. The community read in one line: a genuinely innovative SRAM Eagle Powertrain enduro with auto-shift/coast-shift functionality and proper Transition geometry, but discontinued and superseded by the Bosch-powered Regulator CX.
Drive system and range. The SRAM Eagle Powertrain was a SRAM/Brose collaboration — 90 Nm torque, 680 W peak, 2.98 kg motor weight. The system's headline feature was auto-shift and coast-shift integration with SRAM AXS Transmission, allowing the bike to shift gears automatically based on cadence and torque sensors, even when coasting. @leftside documents the appeal: "How do folks find the auto-shift and coast-shift? These will be new to me, but looking forward to trying them out. Winter here, and gloves are thicker. Not having to shift will be a bonus." Real-world range will sit in the 50 to 70 km territory on Trail/Boost mode.
Geometry and handling. Modern enduro. 63.5 to 64.0 degree head angle depending on size and flip-chip — properly slack. Size-tuned chainstays scale 446-455 mm. Reach progresses 425 mm (SM), 455 mm (MD), 478 mm (M), and up to 510 mm (XL). Wheelbase 1221-1326 mm. @leftside on the bike's playfulness: "The seat tube is already quite low... I can throw this ebike around like no other ebike I've owned." The platform supports 29 or 27.5 inch rear wheels.
Build and value. Three trims. GX AXS at £10,499 (24.0 kg) is the entry point with SRAM GX AXS Transmission integrated with the SRAM Eagle Powertrain motor for auto-shift functionality. (base) trim at the same £10,499 is an alternative spec. X0 AXS at £11,999 (23.9 kg) is the no-compromise top with X0 AXS Transmission. At this price expect Fox Float 38 Performance Elite or RockShox Zeb Ultimate fork, Fox Float X2 or RockShox Super Deluxe Ultimate shock, SRAM Code RSC brakes, and the integrated SRAM AXS drivetrain.
Community-verified strengths.
  • SRAM Eagle Powertrain motor with auto-shift/coast-shift is genuinely novel — no other production eMTB offers this level of drivetrain integration.
  • Size-tuned chainstays (446-455 mm) is properly considered for size-specific feel.
  • @leftside's playful description and Transition's signature geometry mean the platform rides like a proper Transition rather than a heavy eMTB.
Caveats and known gripes.
  • Production status: discontinued. The successor is Transition's Regulator CX with Bosch CX Gen 5 motor — a meaningful upgrade in motor support, noise and ecosystem maturity.
  • @motoadve documented a critical SRAM Powertrain dead-spot issue: "when stopping and restarting pedaling on descents or technical sections, there is no assist initially before it catches. Happens with both auto-shift enabled and disabled. Issue persisted through motor replacement." The early SRAM Powertrain firmware had real-world issues.
  • @JuiceStainV&RStick documented motor cutout at high cadence in boost on technical climbs — appears to be a power-limiter behaviour, frustrating on technical terrain.
  • @abacall notes "The SRAM-equipped Repeater has a non-removable battery, making it more involved than Shimano versions" for rear brake hose routing — service work is harder than rivals.
  • £10,499 entry pricing is premium, especially for a now-discontinued platform.
  • @az2au ranked the Repeater PT as "fine but boring" in a multi-bike SL comparison — the bike performs but isn't class-leading.
Verdict. The Transition Repeater PT 2025 was a properly innovative enduro eMTB with SRAM Eagle Powertrain auto-shift/coast-shift integration — the most ambitious drivetrain-motor coordination ever shipped on a production eMTB. As a current new purchase it's discontinued; used examples at strong pricing remain interesting for riders who want the SRAM ecosystem integration and don't mind the documented dead-spot and cutout issues (which may be resolved on later firmware). For new purchases, look at Transition's own Regulator CX (Bosch CX Gen 5), Pivot Shuttle AM or Norco Sight VLT at similar travel categories. Production status: discontinued.
Geometry read
Size
Wheels
Descending
98
Slack 63.5° head angle, 170mm travel and a long 1292mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
54
Size balance
87
Balanced front-to-rear in L (FC:RC 1.84) — weight sits evenly between the wheels.
Technical climbing
75
SRAM Eagle Powertrain and a steep 78.2° seat angle keep the weight planted over the front — a proper winch. 680W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
How it stacks up vs other Full Power · Gravity bikes (from 136 bikes in the database)
Weight23.95 kgabout average weight
Battery720 Whabout average capacity
Motor torque90 Nm11 Nm below average
Value for moneyPoor value5/100 · from £10,499 vs ~£6,804 for comparable bikes — priced above peers; heavier
💬 Forum discussion
Transition Repeater Owners Thread
22 replies · 8.8k views · last reply 10 months ago
Join the discussion →
“The bike is so good that nobody has anything to write about ;) I'am loving mine. I'ts a real beast of a bike.”
— Lantz · ♥ 4 · most-liked post
Bike geometry diagram
SMLXL
Reach425 mm455 mm480 mm510 mm
Stack630 mm635 mm643 mm652 mm
Seattube380 mm400 mm440 mm470 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle63.5°63.5°63.5°63.5°
Seattube Angle (eff)79.2°78.5°78.2°77.5°
BB Drop25 mm25 mm25 mm25 mm
Wheelbase1230 mm1262 mm1292 mm1326 mm
Headtube110 mm110 mm120 mm130 mm
Standover710 mm720 mm730 mm740 mm
Front Centre766 mm796 mm825 mm860 mm
FC:RC1.701.771.841.91
Trims · 3
GX AXS
£10,499
Repeater PT XO AXS
£11,999
X0 AXS
£11,999
MotorSRAM Eagle Powertrain · 90 Nm · all trims
BatterySRAM Eagle Powertrain 720Wh · 720 Wh · all trims
Travel F/R170/170 mm · all trims
FrameCarbon · all trims
ForkRockShox ZEB Select 170mmRockShox ZEB Ultimate (170mm)RockShox ZEB Ultimate 170mm
ShockRockShox Vivid Select+ 205x65mmRockShox Vivid Ultimate (205x65mm)RockShox Vivid Ultimate 205x65mm
HeadsetFSA NO.55R/44 · all trims
StemANVL Swage 40mmANVL Swage, 40 mmANVL Swage 40mm
HandlebarANVL Mandrel Alloy 800mmOneUp CarbonOneUp Carbon 800mm
GripsODI Elite Flow Lock-On · all trims
SaddleSDG Bel Air 3SDG Bel-Air V3SDG Bel Air 3
SeatpostRockShox Reverb AXS (SM: 150mm, MD/LG/XL: 170mm)RockShox Reverb AXSRockShox Reverb AXS (SM: 150mm, MD/LG/XL: 170mm)
BrakesSRAM Code Bronze StealthSRAM Code Silver Stealth (220mm rotors)SRAM Code Silver Stealth
Rear derailleurSRAM GX AXS Eagle TransmissionSRAM XO AXS Eagle TransmissionSRAM X0 AXS Eagle Transmission
CrankSRAM GX Eagle E-MTB 160mmSRAM X0 Eagle Transmission E-MTB, 160 mmSRAM X0 Eagle E-MTB 160mm
ShiftersSRAM POD Bridge MMXSRAM POD Ultimate Controller, 12-speed AXS wirelessSRAM POD Ultimate Bridge MMX
CassetteSRAM XS 1275 T-Type 10-52tSRAM XS-1295 Eagle Transmission, 10-52TSRAM XS 1295 T-Type 10-52t
ChainSRAM GX Eagle TransmissionSRAM X0 Eagle Transmission FlattopSRAM X0 Eagle Transmission
DrivetrainSRAM GX AXS Eagle TransmissionSRAM XO AXS Eagle Transmission; SRAM X0 Eagle Transmission E-MTB, 160 mm; SRAM POD Ultimate Controller, 12-speed AXS wireless; SRAM XS-1295 Eagle Transmission, 10-52T; SRAM X0 Eagle Transmission FlattopSRAM X0 AXS Eagle Transmission
WheelsDT Swiss H 1900 Spline rims, DT Swiss Hybrid 370 hubsCrankbrothers Synthesis E-Bike Alloy rims, Industry Nine 1/1 hubsCrankbrothers Synthesis E-Bike Alloy rims, Industry Nine 1/1 hubs
TyresFront: Schwalbe Magic Mary Super Gravity Ultra Soft 2.4; Rear: Schwalbe Big Betty Super Gravity Soft 2.4Schwalbe Magic Mary 2.4 front / Big Betty 2.4 rearFront: Schwalbe Magic Mary Super Gravity Ultra Soft 2.4; Rear: Schwalbe Big Betty Super Gravity Soft 2.4
Weight24.01 kg23.95 kg23.95 kg
Price£10,499£11,999£11,999
Rides similarly
Spot a mistake?
