Bike Finder · Transition
Transition Relay
Transition
Relay 2026
CurrentTrail eMTBMature · 6.1/10iFreshness 6.1/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Price
From £6,999
View the Transition Relay on Transition’s site
Transition Relay 2026
From £6,999
EMTB Forums verdict
The Transition Relay is a lightweight, modular trail eMTB built around the 60Nm Fazua Ride 60 motor and a tool-free removable 430Wh battery, so the same chassis can be ridden powered or stripped back to a regular long-travel mountain bike. The Relay and Relay PNW share one frame: a lower shock-mount flip chip swaps between a 29in rear wheel at 160mm travel and a mixed-wheel 170mm setup, and the frame accepts both air and coil shocks thanks to roughly 26 percent progression.
Three builds run off the same SRAM Eagle 90 Transmission drivetrain and SRAM Maven brakes. The £6,999 Alloy 170mm gets a RockShox ZEB Select+ fork, Vivid Coil Select+ shock and a coil-friendly Schwalbe Magic Mary / Big Betty tyre pairing for the heavy-hitting mixed-wheel setup. The £8,599 Carbon 160mm is the lighter 29in trail option with a Lyrik Select+, Super Deluxe Select+ air shock and faster-rolling Maxxis Assegai / Minion DHRII rubber. The top Carbon 170mm steps up to ZEB Ultimate, Vivid Coil Ultimate and Maven Silver brakes.
Geometry is steered by Transition's Speed Balanced Geometry, pairing a 64-degree head angle (63.3 to 63.6 in the slacker PNW mixed-wheel position) with a reduced-offset fork. Reach spans 410mm to 535mm across six sizes from XS to XXL, with steep effective seat angles around 77 to 80 degrees and an uninterrupted seat tube that allows long droppers on every size.
💬 Forum discussion
Transition Relay Owners how's the bike?
242 replies · 81.5k views · last reply 12 months ago
Join the discussion →
“Nearly done with my build (still no battery) finally got all the parts and got the ride wrap installed. Had the bumper removed from the rear shock to move up to 170mm (will prolly replace with a Factory at some point) new Shimano brake…”
— Nerds On Dirt MTB · ♥ 7 · most-liked post
OWNERS’ REPORT
Transition Relay — what owners actually know
1,033 posts · 177 owners · data through May 2026
12Battery retention / connection dropouts (impact shutdowns, no-power-on) · typical onset: First weeks of ownership (factory clip position), or gradually as connector preload…
9Motor-mount bushing creak (the 'FAZUA creak' - frame/interface side) · typical onset: From ~2 months of dusty riding; recurs ~500-2,400km after a grease-only service
9Battery door: rattle, weak latch, water ingress · typical onset: From new
7,300km on one hard-ridden Relay (Tmae) - through 9 motors but the bike keeps getting fixed and ridden, and he's keeping it for the lifetime Fazua warranty…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
XSSMLXLXXL
Reach405 mm422 mm452 mm477 mm502 mm527 mm
Stack588 mm615 mm634 mm643 mm652 mm661 mm
Seattube380 mm390 mm410 mm430 mm460 mm490 mm
Chainstay436 mm440 mm440 mm446 mm446 mm446 mm
Headtube Angle63.6°63.3°63.3°63.3°63.4°63.4°
Seattube Angle (eff)79.3°78.4°77.7°77.1°76.6°76.3°
Wheelbase1172 mm1211 mm1247 mm1282 mm1312 mm1341 mm
Headtube100 mm100 mm115 mm125 mm135 mm145 mm
BB Height343 mm350 mm350 mm350 mm350 mm350 mm
Front Centre736 mm*771 mm*807 mm*836 mm*866 mm*895 mm*
Trims · 3
Alloy 170mm
£6,999
Carbon 160mm
£8,599
Carbon 170mm
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy 430 · 430 Wh · all trims
Travel F/R160/160 mm · all trims
FrameAlloyCarbonCarbon
ForkRockShox ZEB Select+ (170mm)RockShox Lyrik Select+ (160mm)RockShox ZEB Ultimate (170mm)
ShockRockShox Vivid Coil Select+ (205x65mm)RockShox Super Deluxe Select+ (205x60mm)RockShox Vivid Coil Ultimate (205x65mm)
HeadsetFSA No.55R · all trims
StemANVL Swage (40mm) · all trims
HandlebarANVL Mandrel Alloy 35 (XS/SM 800x20mm, MD 800x30mm, LG/XL/XXL 800x40mm)ANVL Mandrel Alloy 35 (XS/SM 800x20mm, MD/LG 800x30mm, XL/XXL 800x40mm)ANVL Mandrel Alloy 35 (XS/SM 800x20mm, MD 800x30mm, LG/XL/XXL 800x40mm)
GripsODI Elite Flow Lock-On · all trims
SaddleSDG Bel Air 3SDG Bel Air 3 LUXSDG Bel Air 3 LUX
SeatpostOneUp Dropper Post (XS 120mm, SM 150mm, MD 190mm, LG 210mm, XL/XXL 240mm) · all trims
BrakesSRAM Maven BronzeSRAM Maven BronzeSRAM Maven Silver
Rear derailleurSRAM Eagle 90 · all trims
CrankRaceFace Aeffect ETOR (165mm, X-Small 160mm), Transition Bash Spider w/ SRAM Eagle Alloy E-Ring 32tRaceFace Aeffect ETOR (165mm, X-Small 160mm), SRAM XX Direct Mount 32t chainringRaceFace Aeffect ETOR (165mm, X-Small 160mm), Transition Bash Spider w/ SRAM Eagle Alloy E-Ring 32t
ShiftersSRAM Eagle 90 MMX Single Click · all trims
CassetteSRAM XS 1275 (10-52t) · all trims
ChainSRAM GX Eagle Transmission · all trims
DrivetrainSRAM Eagle 90; RaceFace Aeffect ETOR (165mm, X-Small 160mm), Transition Bash Spider w/ SRAM Eagle Alloy E-Ring 32t; SRAM Eagle 90 MMX Single Click; SRAM XS 1275 (10-52t); SRAM GX Eagle TransmissionSRAM Eagle 90; RaceFace Aeffect ETOR (165mm, X-Small 160mm), SRAM XX Direct Mount 32t chainring; SRAM Eagle 90 MMX Single Click; SRAM XS 1275 (10-52t); SRAM GX Eagle TransmissionSRAM Eagle 90; RaceFace Aeffect ETOR (165mm, X-Small 160mm), Transition Bash Spider w/ SRAM Eagle Alloy E-Ring 32t; SRAM Eagle 90 MMX Single Click; SRAM XS 1275 (10-52t); SRAM GX Eagle Transmission
WheelsDT Swiss E 1900 Spline 30, DT Swiss 370 Ratchet LN hubs, DT Swiss Champion spokes · all trims
TyresFront: Schwalbe Magic Mary Super Trail Soft (2.4); Rear: Schwalbe Big Betty Super Trail Soft (2.4)Front: Maxxis Assegai 3C EXO+ (2.5); Rear: Maxxis Minion DHRII 3C EXO+ (2.4)Front: Schwalbe Magic Mary Super Trail Soft (2.4); Rear: Schwalbe Big Betty Super Trail Soft (2.4)
Price£6,999£8,599
Rides similarly
Spot a mistake?
