Bike Finder · Thömus
Thömus Lightrider E3 Pro
Thömus
Lightrider E3 Pro 2025
CurrentFull Power · TrailAgeing · 4.6/10iFreshness 4.6/10
Motor
Shimano EP801 · 85Nm · 600W
Battery
Thömus SMP 800 · 800Wh
Travel F/R
170/150mm
Wheels
29F / 29R
Frame
Full carbon
Weight
23 kg
Price
£5,630
View the Thömus Lightrider E3 Pro on Thömus’s site
Thömus Lightrider E3 Pro 2025
From £5,630
EMTB Forums verdict
The Lightrider E3 Pro is Thömus's flagship full-power e-MTB, built around a carbon frame with 150mm of rear travel and a fork that runs from 150mm up to 170mm. Power comes from Shimano's EP801 motor, 85 Nm and 600 W peak, fed by an 800 Wh Samsung-cell pack that can grow to 1,050 Wh with the optional 250 Wh FIDLOCK range extender. That gives it genuine long-tour range alongside the descending capability the travel implies.
Like all Thömus bikes it is sold build-to-order rather than as fixed trims. The frame starts from CHF 5,990 and every component is chosen through the online configurator, which offers three named presets: BASE, ENDURO and TRAIL. The default BASE build leans light and trail-focused with DT Swiss HXC1200 carbon wheels, Vittoria Mezcal tyres and a RaceFace ERA carbon bar, while the geometry can be set to Trail, All Mountain or Enduro character.
Those three geometry configurations are the heart of the bike. The head angle steepens or slackens from 63.6 to 64.4 degrees and the BB drop shifts with fork length, so the same chassis can be tuned from a sharper 64.4-degree trail bike to a 63.6-degree, 170mm Enduro setup. Reach on a size L spans 475 to 483mm depending on configuration, with chainstays held at 445mm across all sizes.
Neat touches reflect the Swiss attention to detail: a USB-C charging port in the headset, a fully integrated EightPins dropper and hidden mounts for mudguards and a kickstand for an SUV-style touring build. Claimed weight is from 23kg.
Geometry read
Size
Setting
Descending
71
A solid all-round descender (63.6° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
66
Short 445mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
60
Not enough geometry on record to judge size balance.
Technical climbing
54
Climbs well — a 76.2° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 241 bikes in the database)
Weight23 kgabout average weight
Battery800 Wh95 Wh above average
Motor torque85 Nm13 Nm below average
Value for money70/100from £5,630 · most Shimano EP801 bikes ~£6,480
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Reach427 mm454 mm481 mm507 mm
Stack624 mm637 mm651 mm665 mm
Seattube395 mm425 mm454 mm490 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle64.2°64.2°64.2°64.2°
Seattube Angle (eff)76.7°76.7°76.7°76.7°
Wheelbase
Headtube100 mm115 mm130 mm145 mm
Front Centre
FC:RC
Trims · 1
Base
£5,630
MotorShimano EP801 · 85 Nm
BatteryThömus SMP 800 · 800 Wh
Travel F/R170/150 mm
FrameCarbon
HeadsetIntegrated, with USB-C charging port
StemThömus Ursa Ø35mm, 35mm
HandlebarRaceface ERA Carbon Riser Pro 780mm
GripsESI Silicone Chunky, black
SaddleSelle San Marco Ground Short
SeatpostKind Shock LEV Integra 150mm
WheelsDT Swiss HXC1200 30mm Carbon (tubeless option)
TyresVittoria Mezcal 29x2.60
Weight23 kg
Price£5,630
Rides similarly
Spot a mistake?
