A solid all-round descender (65.5° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Lightrider E2 2025
Swiss-built lightweight Shimano EP8 carbon eMTB from 18.5kg
The Thömus Lightrider E2 2025 is the Swiss brand's flagship lightweight carbon eMTB, built around the Shimano EP801 motor (85 Nm, 250 W rated, 600 W peak, 2.7 kg) and a 726 Wh removable battery. Travel is 150 mm front and rear, head angle 65.5°, and Thömus quotes a 21.8 kg claimed weight across four sizes (S/M/L/XL). UK pricing opens at £8,999. There's minimal community footprint on this exact model on the forum — Thömus is a Swiss specialist with a strong domestic following and limited UK presence — but the brand has built a serious reputation for handcrafted Swiss carbon frames since the 1990s and the Lightrider line is well-regarded in alpine markets.
Drive system and range. The Shimano EP801 produces 85 Nm of torque and 600 W peak power. While now mid-pack against the Bosch CX Gen 5 (120 Nm) and DJI Avinox M2S (150 Nm) on raw figures, the EP801 has been refined through firmware updates and remains a smooth, quiet and proven motor. The 726 Wh battery is generously sized for a lightweight platform — substantially more than the typical 400-540 Wh found on rivals like the Fantic Rampage or Instinctiv Ocelot. Expect 1,100-1,500 m of climbing per charge depending on terrain and assist mode. The pack is removable for easy off-bike charging. E-Tube Project app integration provides ride mode customisation, ride data and firmware updates.
Geometry and handling. A 65.5° head angle is squarely modern-trail and a touch steeper than the most aggressive lightweight eMTBs but well-judged for the bike's all-rounder intent. Reach progresses S 415 mm, M 445 mm, L 475 mm, XL 500 mm — a generous 25-30 mm step between sizes with proper modern sizing. Chainstays grow from 453 mm on the smaller frames to 455 mm on L and XL — a small step but reflects Thömus's attention to weight distribution across sizes. The geometry suits Alpine trail use rather than aggressive UK enduro hammering, which fits the bike's Swiss-engineered all-day-pedalling philosophy.
Build and value. The £8,999 base trim is premium money. Expect Fox 36 Factory Kashima or Fox 36 Performance Elite forks, Fox Float X or Float DPS Performance shocks, Shimano XT/SLX 12-speed drivetrain and four-piston hydraulic brakes. Thömus offers customisation through its Swiss factory, including paint and finish options, and the brand's heritage in handcrafted frame production shows in the quality of construction. As a small-volume Swiss brand, the Lightrider E2 also commands the kind of premium that boutique brands like Pole, Crestline or Instinctiv enjoy — buyers pay for engineering and provenance rather than mass-production scale.
Caveats and known gripes. Thömus's UK and US dealer footprint is thin — the brand is strongest in Switzerland, Germany and Austria. Buyers outside DACH need to confirm warranty and service paths before purchase. The £8,999 price is hard to justify against newer Avinox-equipped rivals like the Crussis E-Full 12 (£5,060) or MMR Lyth (£5,999) which offer carbon construction, larger batteries and more powerful motors at substantially less money. The Shimano EP801's 85 Nm is now mid-pack against the latest Bosch/DJI motors. Community ownership data is minimal, so long-term reliability evidence is thin. The 65.5° head angle is conservative — riders chasing modern slack-and-long geometry will look elsewhere. Thömus's distinctive aesthetics (yellow Swiss colourway is the brand signature) aren't for everyone.
Verdict. The Lightrider E2 is for the rider who values Swiss-engineered carbon provenance, handcrafted Thömus heritage and a balanced 150/150 mm lightweight trail platform with a class-leading 726 Wh battery. It suits Alpine and DACH-based buyers willing to pay a premium for boutique build quality and Thömus's domestic service network. It is not for value-focused buyers, riders chasing the latest 100+ Nm motors, those outside the Swiss dealer footprint, or anyone who wants the most aggressive trail geometry available. Production status is current and the bike continues into 2026.
Short 455mm rear and a lighter build — easy to pop, manual and throw around.
Not enough geometry on record to judge size balance.
A workmanlike climber — expect to put in more rider effort on the steep stuff. 600W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
Lower torque or a slacker seat angle — fine, just don't expect a winch.
How it stacks up vs other Full Power · Trail bikes (from 241 bikes in the database)
| S | M | L | XL | |
| Reach | 415 mm | 445 mm | 475 mm | 500 mm |
| Stack | 615 mm | 624 mm | 634 mm | 638 mm |
| Chainstay | 453 mm | 453 mm | 455 mm | 455 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 75.4° | 75° | 74.7° | 74.5° |
Trims · 1
Base £8,999 | |
| Motor | Shimano EP801 · 85 Nm |
| Battery | Thömus 726Wh · 726 Wh |
| Travel F/R | 140/140 mm |
| Frame | Carbon |
| Weight | 21.8 kg |
| Price | £8,999 |
Rides similarly
Spot a mistake?
